Homewizard websocket
In the new Homewizard v2 api there's a websocket to receive device updates, see:
WebSocket | HomeWizard Energy API Documentation
From the forum i used an example, but i received an error:
* table:
["type"]
  * string: authorization_requested
["data"]
  * table:
   ["api_version"]
    * string: 2.0.1
* string: receive failed: error:0A000126:SSL routines::unexpected eof while reading
My code
if not client then
  ws = require('user.websocket')
  json = require('json')
  local ip = 'MYIP'
  local token = 'MYTOKEN'
  local url = 'wss://' .. ip .. '/api/ws'
  client, err = ws.client('sync', 10)
  res, err = client:connect(url)
  if res then
    -- send authorization
    client:send(json.encode({
      type = 'authorization',
      payload = 'data=' .. token,
    -- subscribe op batteries
        --client:send(json.encode({
          --type = 'subscribe',
          --data = 'batteries'
    log('connection failed: ' .. tostring(err))
    client:close()
    client = nil
  data, _, _, opcode, err = client:receive()
  if data then
    data = json.pdecode(data)
    if data then
      log(data)
    log('receive failed: ' .. tostring(err))
    client:close()
    client = nil
Try sending auth this way:
  data = token,
You might need to wait for authorization_requested to be sent by the server fist before sending the authorization command.
and how to setup the code to connect to multiple devices (+- 10 devices)?
(16.10.2025, 09:39)admin Wrote: Try sending auth this way:
  data = token,
It works, i see data but also:
* string: receive failed: protocol error
and
* string: connection failed: timeout
If you need multiple websockets then create a separate script for every connection. A user library can be helpful to avoid copy/pasting the same code.
timeout error can be ignored, it simply means that there's no data to be read at this moment. You can increase the timeout value if the data is guaranteed to be sent at least once every X seconds.
(16.10.2025, 10:11)admin Wrote: If you need multiple websockets then create a separate script for every connection. A user library can be helpful to avoid copy/pasting the same code.
Something like this?
Resident script
require('user.nit_homewizard')
clientHandler(1)
User library  nit_homewizard
--https://api-documentation.homewizard.com/docs/v2/websocket
debug = false
-- all homewizard devices (client, ip, token)
local cDevices = { {nil, 'YOURIP', 'YOURTOKEN'} }
function clientHandler(iDevice)
  if not cDevices[iDevice][1] then
    local ip = cDevices[iDevice][2]
    local token = cDevices[iDevice][3]
    cDevices[iDevice][1], err = ws.client('sync', 10)
    res, err =  cDevices[iDevice][1]:connect(url)
    if res then
       cDevices[iDevice][1]:send(json.encode({type = 'authorization',data = token}))
      -- identify
      -- cDevices[iDevice][1]:send(json.encode({type = 'identify'}))
      -- polling data once
       cDevices[iDevice][1]:send(json.encode({type = 'system'}))
      -- (un)subscribe
       cDevices[iDevice][1]:send(json.encode({type = 'subscribe',data = '*'}))
      -- subscribe op device info
      --cDevices[iDevice][1]:send(json.encode({type = 'subscribe',data = 'device'}))
      -- subscribe op system info
      --cDevices[iDevice][1]:send(json.encode({type = 'subscribe',data = 'system'}))
      -- (un)subscribe op measurement
      --cDevices[iDevice][1]:send(json.encode({type = 'subscribe',data = 'measurement'}))
      cDevices[iDevice][1]:send(json.encode({type = 'unsubscribe',data = 'measurement'}))
      -- subscribe op batteries (werkt niet, onbekend)
      --cDevices[iDevice][1]:send(json.encode({type = 'subscribe',data = 'batteries'}))
      -- setting data
      --{ "type": "system", "data": { "cloud_enabled": false } }
      if debug then
       cDevices[iDevice][1]:close()
       cDevices[iDevice][1] = nil
    data, _, _, opcode, err =  cDevices[iDevice][1]:receive()
    if data then
      if data then
        log(data)
      if debug then
A simpler way:
function clientHandler(ip, token)
  if not client then
clientHandler('192.168.192.168', '123456')
