Hi group!
I'm trying to use HTML to have an editable table in LogicMachine, the goal in this project is to give the user the possibility to edit a list of users. I have a script were I put my HTML page. My bdd is in a .json script, and in my HTML code I have two funtion, x_get.lua and x_save.lua. In my x_get.lua i have the next script:
In my x_save.lua
The firmware version of my homeLYnk is:
HW: LM5 Lite (i.MX6)
The problem is that when i try to get into my get.lua, the response is a text, not the list of user that i have in my .json script.
In my version of LM I don't get acces to the /user/ file or the /ww/ file, I ask ChatGPT and it said that I have to create my scripts in those files, because when I try to get into the next url: IP-Server:port/x_get.lua, the response is a text and when I try to get into IP-Server:port/x_save.lua the response is 404 Not Found.
I try to update some packages in the LM, from an new version of homeLYNk, but the packages are:
url.lua
ftp.lua
http.lua
and the packages that are supported are .ipk.
I cannot upgrade the firmaware of the LM, because I don't want to lose the connection with the phisical machines that I have in the project.
Can someone help me with this issue please? Will appriciated!
content("application/json")
local f = io.open('user/inquilinos.json', 'r')
if not f then
print("[]")
return
local data = f:read("*a")
f:close()
print(data) In my x_save.lua
-- Leer cuerpo del POST
local len = tonumber(os.getenv("CONTENT_LENGTH") or 0)
local body = ""
if len > 0 then
body = io.read(len)
if not body or #body == 0 then
print('{"status":"error","msg":"POST vacío"}')
return
-- Intentar escribir el archivo JSON
local f, err = io.open("/www/user/inquilinos.json", "w")
if not f then
print('{"status":"error","msg":"No se pudo abrir el archivo: '..tostring(err)..'"}')
return
f:write(body)
f:close()
print('{"status":"ok"}')The firmware version of my homeLYnk is:
url.lua
ftp.lua
http.lua
