Good morning Team,
I have a problem in custom widget. I have created custom widget, enabled 'compact mode' and setting as picture attached. But I'll guest to seen a widget with inside the name 'PANNELLI TERMICI' but as you can seen Visu shows 'Custom widget'. Where am I wrong?
Best regards Cristian Grassi
11.11.2025, 13:30 (This post was last modified: 11.11.2025, 13:33 by AlexLV.)
Hi Daniel,
I installed latest version for testing - visu20251110-2. And I see problem - I lost background picture for custom widgets - just black background. For simply widgets background picture is ok - no any changes.
But at site already installed sw 20250813. Maybe problem because of it?
Hi, when I use the thermostat widget on a mobile device, it closes automatically when I tap it, forcing me to reopen it to raise or lower the temperature by one degree. This happens on both an Android tablet and an iPhone. It works correctly on a computer.
