New widgets
#41
Add to Custom CSS:
.widget-content-trends .widget-content-widget,
.widget-trends .tile-widget-content-widget {
  border-radius: 8px;
(24.11.2025, 07:27)admin Wrote: Add to Custom CSS:
  border-radius: 8px;
Cool. Thanks.
Will the option to import or export custom widgets be implemented?
Plans/layouts/widgets will have import/export feature.
Hello. I'm not sure if this has already been discussed here.
1. In the Mosaic version, there's an option to add a category bar. Since I usually customize it, and for faster processing, could you add the ability to duplicate an existing bar, like with any other widget?
2. Regarding widgets, I'm missing a combination of a slider widget and a 1-bit motion widget to control the blinds. The circular or vertical slider allows you to add minimum/maximum buttons, but it's missing a stop button. It would be great to add and be able to select that option.
Could the inverted object option be integrated into the on/off control widgets? The previous tile included this option.
What do you mean by 'power control widgets' ?
(28.01.2026, 14:06)Daniel Wrote: What do you mean by 'power control widgets' ?
I'm referring to the on/off controls. I've attached an image of the old and new mosaic.
You can fully customize how ON and OFF states look. Are you sure that inverse option is really needed?
(29.01.2026, 08:26)admin Wrote: You can fully customize how ON and OFF states look. Are you sure that inverse option is really needed?
In the case of this control, only the icon associated with the button can be customized. For me, this control is quite useful and quick for switching between Automatic/Manual and On/Off modes. These controls typically use the value "true" when visually disabled.
The other on/off control we have requires complete customization, and the icon is limited when you want to adjust it to a specific size and area.
In my opinion, this would be a positive improvement and would greatly streamline the process.
Hello there. Do we have any widgets for shutter control in Visu? I don't see any. I have a LM4 which i updated with the last available firmware. Thank you.
stavros
Movment 1bit, otherwise you can use sliders.
Airconditioner Widget as they don’t use the 20 hvac dpt
Hi, the option to invert the object is already implemented in the switch widget. I would like it to be available in the toggle widget as well, if possible. Thank you.
@davidchispas, Invert option for Toggle widget will be added in the next version.
@KoBra, can you describe what features are needed in the AC widget apart from setpoint control and current temperature display?
(31.03.2026, 11:26)admin Wrote: @KoBra, can you describe what features are needed in the AC widget apart from setpoint control and current temperature display?
On/Off
Set Temperature
Actual Temperature
Mode (Cool/Heat/Auto/Fan/Dry) Not all are available on every manufacturer and a lot of manufacturers use a different output number to switch
Fan Speed (Super Low / Low / Mid / High / Super High /Auto)  Not all are available on every manufacturer and a lot of manufacturers use a different output number to switch
So in Basis it can be the same as the current Thermostat but mainly the MODE and FAN are not the same or usable. I now solve it with 2x additional text selector but they are large and not really ideal to match the visual of the thermostat.
