Realtime Clock
Is it possible to display the RTC inside the LM in Visu?
Custom JavaScript example that adds current time near the close button. Header option must be enabled in General settings for this to work in Plan view.
const el = document.querySelector('.navbar > .container-fluid > div:last-child')
if (el) {
  const span = document.createElement('span')
  span.classList.add('me-2', 'd-flex', 'align-items-center')
  el.prepend(span)
  const update = () => {
    const date = new Date()
    span.textContent = date.toLocaleTimeString()
  setInterval(update, 500)
  update()
After implementing the time via JS the main title is shifted to the left, can this be resolved?
[Image: tlEFY0Z.png]
Try this:
if (el) {
  el.classList.add('position-relative')
  span.classList.add('position-absolute', 'top-0', 'bottom-0', 'd-flex', 'align-items-center')
  span.style.right = '120%'
  el.prepend(span)
  update()
is possible provide Custom JavaScript for Tile View also?
Alex
(09.04.2026, 17:28)AlexLV Wrote: Hi,
Alex
It works in Tile view as well.
If you want 24 hour format and date here is an example
if (el) {
  span.style.right = '130%'
  el.prepend(span)
  span.textContent = date.toLocaleString('en-GB', {
    day: '2-digit',
    month: '2-digit',
    year: 'numeric',
    hour: '2-digit',
    minute: '2-digit',
    second: '2-digit',
    hour12: false
  }).replace(',', '')
  update()
If you only want time in 24H format without seconds:
span.textContent = date.toTimeString().substring(0, 5)
