Device: LM5P2-KDCZ
I'm unable to use the "data16" (0x09) data type in a Lua script.
I'm trying to trigger a Zigbee device using this event-based script. While running the script, I monitor all messages sent to the device using Wireshark.
With this script, I don't see any messages being sent, and I get a "no response" error in the LogicMachine logs.
If I change the data type to "uint16", for example, and run the script again, I can see that a message is sent to the device with Wireshark. However, it does not trigger the expected action, which is understandable since the data type is different.
Here, you will find a capture of a message sent using another Zigbee tool. This is the message I would like to send using this script.
Does anyone know how to send a command with the "data16" data type from a Lua script?
If some Zigbee Cluster Library (ZCL) data types are not supported by LogicMachine, is there any documentation available listing the supported data types?
Device: LM5P2-KDCZ
local zb = require('applibs.zigbee')
local address = '0004740001248162'
local manufcode = 4129
local mode = event.getvalue()
local res, err = zb.cmdsync('setrawattribute', address, 64513, 0, mode, 'data16', manufcode)
if not res then
log('Writting error on contactor (' .. address .. '): ' .. tostring(err))
log('Contactor mode: ' .. tostring(mode))
endQuote:Log :
Event for Mode contacteur (33/1/1) 20.07.2026 08:49:27
* string: Writting error on contactor (0004740001248162): no response
