copas connecting to tcp server cannot receive percentage
Ok so I have a resident script using a copas udp server on the localhost to receive commands from knx objects (event script) , then there is a copas tcp client connecting to an tcp server on the local network. I did it this way so they don't block each other.  The issue I am experiencing is that when the tcp server sends out an percentage character the tcp client stops receiving anything else from the server.
Does someone have an idea?
Thanks,
Roger
if not ready then  socket = require("socket")  copas = require("copas")  alert('not Ready')  ready=true    function parse(data)    alert('parsing...  '..data)  end      function fromKNX(command)   alert('from KNX.. '..command)  end    local server = socket.udp()  server:setsockname("127.0.0.1",23456)  function handler(skts)    skts = copas.wrap(skts)    alert("UDP connection handler")    while true do      local s, err      alert("UDP receiving...")      s, erro = skts:receive(2048)      if not s then        alert("UDP Receive error: ", erro)        break      end      alert("Received data, bytes: "..s)      fromKNX(s)    end  end  copas.addserver(server, handler, 1)   end if not skt then  alert('not socket')  if skt then    skt:close()    skt = nil  end  -- create tcp client  skt, err = socket.connect('10.10.10.41', 4999)  skt:settimeout(0)  copas.addthread(function()      while true do       local resp,err = copas.receive(skt)        if not resp then          alert("TCP Receive error: ", err)          break        end        parse(resp)      end    end)  -- connect ok, reset buffer  if skt then    alert('[tcp-client] connection ok')    warningfailed = true    init()    -- error while connecting,  else    if warningfailed then alert('[tcp-client] connection failed (conn): %s', err) end    warningfailed = false  end   end copas.loop()
Default receive behaviour is to read a single so it will not return until a new line ("\n") character is found in the buffer. Are you sure the server is sending it correctly?
Hi Admin,
Yes, I am testing with the hercules tcp server. for example, i send
1234
12345%
and I don't see 12345% as a alert.
If I then restart the script and send %% then I receive a single % in the alert and then I can continue sending from the tcp server and the client resident script continues to alert the received data.
Thanks,
Roger
You can get the hercules app from http://www.hw-group.com/products/hercules/index_en.html
Alert behaves like string.format and if you pass 12345% it will result in an error. This will be fixed in RC4. For now, just change alert to log.
So I changed the copas.addthread function.
 copas.addthread(function()      while true do       local resp,err = copas.receive(skt,'*l')        if not resp then          alert("Jandy Receive error: ", err)          copas.removeserver(skt)          skt = nil                    break        end        parse(resp)      end    end)
Now when I send % I see in the alerts
there was an error/usr/share/lua/genohm-scada.lua:0: bad argument #2 to 'format' (no value)
Any ideas?
Thanks,
Roger
function parse(data)   alert('parsing: %s', data) end
Ok, wow... so everything was blocking because the alert statement couldn't concatenate the string?
Big thanks Admin
Thanks,
Roger
