Android and IOS Application is released for Logic Machine
Hello ,
We released a Android and IOS Application for Logic Machine. Main objective of this application is a need of app in some projects and a stable visualization access without entering username and password or confirming username and password every time.
You can find the applications both Google Play Store or IOS App Sore searching LMhome name.
This is the IOS Application : https://itunes.apple.com/tr/app/lm-home/...99806?mt=8
This is the Android Application : https://play.google.com/store/apps/detai...ewer&hl=tr
Also there is simple usage manual that you can find as a attachment in this post.
Please do not hesitate to post your comments and simple change needs. We will do it.
By the way , we are preparing a pro version of this application which contains a lots of future.
For Android , Android 5.1 and upper version are supported. For IOS , IOS 8 and upper versions are supported.
For LM3, LM4 , LM5 and LM3Reactor tests are ok. If you have isssue with other LM devices and firmware, please let us know and we will try to support as much as possible.
Regards
.pdf   LM Home Mobile V01.pdf (Size: 944.41 KB / Downloads: 60)
Regarding to wish list , we are planning to release a new version soon.
English link to Google Play is here: https://play.google.com/store/apps/detai...hineviewer
What is the minimal Android version? Plenty of us use obsolete devices for home automation and this software can't be installed on my Samsung Galaxy 8.8 (Android 4.04).
Does the app support a real full fullscreen mode? I see upper OS row at your printscreens.
LM5Lp, firmware: 2018.08.22, FlashSYS v2, ARMv7 Processor rev 5 (v7l), kernel 4.4.151
What is the added value compare with 'add to homescreen' function?
Password can also be stored by using 'add to homescreen' so i don't need this app for that..
As far as i can tell it's just a container holding the html page.
Or do i miss something?
I think it is very nice direction, if it is about a wishlist:
- auto-switching between local and remote address,
- https,
- local storage of backgrounds.
I think an app is much more flexible than "Add to homescreen", because it is much more easier to change its address, it has specific icon.
- if it is about pro version, you can offer a cloud like Schneider RemoteApp.
(21.06.2017, 16:19)Thomas Wrote: English link to Google Play is here: https://play.google.com/store/apps/detai...hineviewer
This app is supporting real full screen mode.
Software is supporting Android 5.1 and upper versions.
(21.06.2017, 16:58)Erwin van der Zwart Wrote: Hi,
Hi Erwin,
There are 2 added  value for this minimal version. Pro version it will more.
1-) In classic way, yes password is stored but you have to approve your username and password everytime. Also , you have switch betwwen chrome and fullscreen mode to see username and password approval screen and it's really diffucult for some basic users. Please don't think about yourself. There are lots of customer have problems with this switching system and approval. Our app is making simple this situation. Only first installation you will enter username and password. Later, when you open app, directly user interface will appear. We need this function because of variety of customer.
2-) Web interface has a big problem with changing network. For example , you are at your home or work and you connected to wi-fi. Then you are going to out you will connect to 3G or 4G. This change effects web interface control buttons. You can change pages but you cannot send a command to Logic Machine. You have to close web interface and open web interface one more time. This is a huge problem for ordinary home automation users. They forget the process and they are complaining a lot. But our application can understand the network change automatically and refresh connection automatically also.
This simple application aims to end those end user complains.
Regards,
(21.06.2017, 19:20)buuuudzik Wrote: I think it is very nice direction, if it is about a wishlist:
- https,
- Auto-switching between local and remote address is supporting already. This is one of the reason why we did this application.
- Https is a problem with Logic Machine mostly but we are working on it. We will support I believe soon.
- Some part, we did it and we will made it better. There are some little issues. Next version will be much better.
Hi Erwin,
Regards,
- https,
I don't see it at the screens(that there is a place when you can type remote address), but are you sure?
Also you can add if it is possible turning on the chosen VPN when LM is not available by LAN.
