16.06.2017, 23:40
Maybe this helps someone. Here is basic bi-directional example for connecting the LM to some device that is controlled over TCP.
Thanks,
Roger
Place a resident script with a sleep interval of 0
Create event based script for
Thanks,
Roger
if not ready then
socket = require("socket")
copas = require("copas")
alert('not Ready')
ready=true
function parse(data)
alert('parsing: %s', data)
-- use this function to parse the data you receive from the tcp device
function sendTo(command)
skt:send(command)
--optional delay between commands sent tcp device you are controlling
sleep(1)
function fromKNX(command)
alert('from knx: %s', command)
local telegram = string.split(command,',')
-- for every object that has the event script
if(telegram[1]=='1/1/1')then
sendTo('thisComand ='..telegram[2]..'\r')
-- use this function to get the status of the remote tcp device
function init()
alert('Getting status of tcp device')
sendTo('some command \r')
local server = socket.udp()
server:setsockname("127.0.0.1",23456)
function handler(skts)
skts = copas.wrap(skts)
alert("UDP connection handler")
while true do
local s, err
alert("UDP receiving...")
s, erro = skts:receive(2048)
if not s then
alert("UDP Receive error: ", erro)
break
alert("Received data, bytes: "..s)
fromKNX(s)
copas.addserver(server, handler, 1)
if not skt then
-- create tcp client
skt, err = socket.connect('10.10.10.41', 4999)
-- when theres no error connect ok, initialize
if(not err) then
skt:settimeout(0)
-- add receive thread
copas.addthread(function()
while true do
local resp,err = copas.receive(skt)
-- if theres no connection start a new connection
if not resp then
alert("[tcp-client] Receive error: %s", err)
copas.removeserver(skt)
skt = nil
break
parse(resp)
end)
if skt then
alert('[tcp-client] connection ok')
-- optional init function use to get initial status of remote device
-- init()
-- error while connecting,
if warningfailed then alert('[tcp-client] connection failed (conn): %s', err) end
return
alert('[tcp-client] error connecting %s',err)
return
copas.loop()
if event.type=='groupwrite' then
require('socket')
local client = socket.udp()
local evt = event.dst..','..tostring(event.getvalue())
if client then
client:sendto(evt, '127.0.0.1', 23456)
client:close()
elseif event.type =='groupread' then
grp.response(event.dst,event.getvalue())
