Control Bose Lifestyle 650 Home Entertainment System
Hi all,
Right now I'm having some problems with the Bose 650 LifeStyle, I can not get its infrared signal (IR) because it uses Radio (RF) signal. Can I control it over TCP or HTTP?  Sad Sad
May you help me solve this, I will be very happy.
Thank you very much.
Looks like it supports HTTP commands over port 8090:
http://support.iridiummobile.net/uploade...c0fcc7.pdf
(26.07.2017, 09:55)admin Wrote: Looks like it supports HTTP commands over port 8090:
Thanks for your information,
But I do not know how to start from scratch, you can give me an example of it. This is new to me.
I will be very grateful.
Try running this script once, change IP variable as needed. It should return XML with current volume settings.
IP = '192.168.1.10' http = require('socket.http') url = 'http://' .. IP .. ':8090/volume' res, err = http.request(url) log(res, err)
(26.07.2017, 10:21)admin Wrote: Try running this script once, change IP variable as needed. It should return XML with current volume settings.
I tried to use this way, but it does not work, hopefully there is another way Sad
I look forward to feedback from you
