Memory Usage
Sad
Hello!
I'm have a problem with the memory load/usage on my LM Ambient.
Whenever i reset the LM Ambient, the Memory load is around 15-19%, but each day it increases by 2-4%.
A few days ago the load was at 90%, so I tried installing the newest firmware, but the same thing keeps happening.
Is there a possibility that any of my scripts could be causing this? I'm relatively new to LUA so it would be fair to assume that this might be of my own doing!
Some additional info
I have attached my trend logs.
No object logs are active.
I'm only using Z-Wave products, about 40 of them are connected to my LM.
A function/user.library that is called every 1 second for 4 different light zones in the same resident script
function auto_lysstyring(auto_on, nattsenking, sensor, light_type, light_control, dim_value_day, dim_value_night, off_time)    if grp.getvalue(auto_on) == true then       offtime = off_time -- Tid i minutter for å slå av lys etter siste bevegelse     dim_day = dim_value_day -- Dimmeverdi på dagtid     dim_night = dim_value_night -- Dimmeverdi etter nattsenking     nattsenk = grp.getvalue(nattsenking) -- Henter nattsenk status true/false     mov_sensor = grp.getvalue(sensor) -- Sjekker bevegelse i rommet  light_type_check = light_type  light_control_check = grp.getvalue(light_control)  obj_find = grp.find(sensor)     delta = os.time() - obj_find.updatetime        if light_type_check == 1 then -- Light type 1 for dimming      if mov_sensor == true then        if light_control_check < 10 then          if nattsenk == true then            grp.update(light_control, dim_night)            elseif nattsenk == false then            grp.update(light_control, dim_day)            end          end      end            if mov_sensor == false and delta >= offtime * 60 then        if light_control_check > 0 then          grp.update(light_control, 0)          end      end    end        if light_type_check == 0 then -- Light type 1 for av/på      if mov_sensor == true then        if light_control_check ==false then          grp.update(light_control, true)          end        end            if mov_sensor == false and delta >= offtime * 60 then        if light_control_check == true then          grp.update(light_control, false)        end              end          end      else  end   end
A resident script that runs every 5 seconds
obj_find = grp.find('1/1/35') -- Gesture sensor value delta = os.time() - obj_find.updatetime if delta >= 5 and delta < 9.99 then  gesture = grp.getvalue('1/1/35') -- Green light, ECO Mode. Sets thermostats to ECO and turns off all lights if gesture == 1 then    -- upate HVAC MODE to ECO  grp.update('1/1/66', 3)    -- Turn off all lights  bit_objects = grp.tag('ALT_AV_BIT')     byte_objects = grp.tag('ALT_AV_BYTE')  for index, value in ipairs(bit_objects) do      grp.update(value.address, false)     end     for index, value in ipairs(byte_objects) do      grp.update(value.address, 0)     end   end -- Orange light, Comfort mode. Sets thermostats to Comfort, lights are untouched. if gesture == 2 then  -- upate HVAC MODE to Comfort  grp.update('1/1/66', 1) end -- Black Light, turns off all lights. if gesture == 3 then  -- Turn off all lights  bit_objects = grp.tag('ALT_AV_BIT')     byte_objects = grp.tag('ALT_AV_BYTE')  for index, value in ipairs(bit_objects) do      grp.update(value.address, false)     end     for index, value in ipairs(byte_objects) do      grp.update(value.address, 0)     end   end -- yellow Light, turns on all lights. if gesture == 4 then  -- Turn off all lights  bit_objects = grp.tag('ALT_AV_BIT')     byte_objects = grp.tag('ALT_AV_BYTE')  for index, value in ipairs(bit_objects) do    grp.update(value.address, true)     end     for index, value in ipairs(byte_objects) do      grp.update(value.address, 90)     end   end end
A resident script that runs every 60 seconds
-- get an array of objects tagged 'tag name' myobjects = grp.tag('Battery') batteryfails = 0 -- arraytable = { 'a', 'b', 'c' } for index, value in ipairs(myobjects) do  batterycheck = grp.getvalue(value.address)  if batterycheck < 10 then --rapporterer alle batterier under 10%    batteryfails = batteryfails + 1 end     end if batteryfails > 0 then        grp.update('1/1/105', batteryfails)  grp.update('1/1/104', true) elseif batteryfails == 0 and grp.getvalue('1/1/104') == true then  grp.update('1/1/105', batteryfails)  grp.update('1/1/104', false) end
Run this script and post what you get in Logs:
res = io.readproc("ps | grep -v '\\['") log(res)
Dummyscript 12.09.2017 11:18:34 * string:   PID USER       VSZ STAT COMMAND    1 root      1088 S    /sbin/init  609 root      1108 S    /sbin/syslogd -C16  611 root      1088 S    /sbin/klogd  613 root       848 S    /sbin/hotplug2 --override --persistent --set-rules-f  793 root      1088 S    /sbin/watchdog -t 5 /dev/watchdog  889 root       716 S    /usr/sbin/gpiod -i -l /lib/restore/defaults.sh -d /l  898 root      1092 S    /usr/sbin/ntpd -n -p 0.europe.pool.ntp.org -p 1.euro  908 root      3108 S <  /usr/bin/eibd -e 15.15.255 -q 100 -D -L 1 -Q 0 -T -S  912 root     13680 S    /usr/sbin/redis-server /etc/redis.conf 1414 root      2412 S    lua /lib/genohm-scada/core/scenes.lua 1416 root      2652 S    lua /lib/genohm-scada/core/groupmonitor.lua 1424 root      2508 S    lua /lib/genohm-scada/plugins/ble/bgscan.lua 1428 root      4416 S    lua /lib/genohm-scada/plugins/enocean/daemon.lua 1430 root      2728 S    lua /lib/genohm-scada/plugins/lmwall/daemon-sensors. 1431 root      2228 S    lua /lib/genohm-scada/plugins/lmwall/daemon-led.lua 1432 root      2552 S    lua /lib/genohm-scada/plugins/lmwall/daemon-apds.lua 1434 root      2552 S    lua /lib/genohm-scada/plugins/w1/daemon.lua 1453 root      1576 S    owserver --i2c=/dev/i2c-0:0 -p 127.0.0.1:4304 1458 root      2300 R    lua /lib/genohm-scada/core/scripting-resident.lua 26 1462 root      2224 S    lua /lib/genohm-scada/core/scripting-resident.lua 28 1468 root      2324 S    lua /lib/genohm-scada/core/scripting-resident.lua 32 1509 root      3648 S    nginx: master process nginx -c /etc/nginx.conf 1510 root      5848 S    nginx: worker process 1524 root      1096 S    /usr/sbin/crond -l 20 -c /etc/crontabs 6110 root      2540 S    lua /lib/apps/daemon.lua zwaveapp /home/apps/store/d 6148 root      2148 S    /home/apps/usr/sbin/zwave /home/apps/usr/share/openz 6149 root      7780 S    /home/apps/usr/sbin/zwave /home/apps/usr/share/openz 8746 root      1092 R    ps
That looks normal, do you have many trends created? Can you check how much is /tmp using in system config > status > system status > partitions?
My trend logs are attached as a picture in the first post.
I have attached a picture of the partitions in this one.
Can you provide remote access to your device? Please contact us by e-mail.
