Rewrite Curl to LUA?
Can anyone tell me if this sample script can be "transplanted" to LM?
<?php $username = 'xxx@xxx.xxx'; $password = 'xxx; $serial = 'xxx'; $nonce; $jsessionid; $token; $curl = curl_init(); curl_setopt_array($curl, array( CURLOPT_URL => "https://my.zipato.com/zipato-web/v2/user/init";, CURLOPT_RETURNTRANSFER => true, CURLOPT_ENCODING => "", CURLOPT_MAXREDIRS => 10, CURLOPT_TIMEOUT => 30, CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1, CURLOPT_CUSTOMREQUEST => "GET", CURLOPT_HTTPHEADER => array( ), )); $response = curl_exec($curl); $err = curl_error($curl); curl_close($curl); if ($err) { echo "cURL Error #:" . $err; } else { $json = json_decode($response, true); $nonce = $json['nonce']; $jsessionid = $json['jsessionid']; $password = sha1($password); $token = $nonce . $password; $token = sha1($token); } $curl = curl_init(); curl_setopt_array($curl, array( CURLOPT_URL => "https://my.zipato.com/zipato-web/v2/user/login?token=$token&username=$username";, CURLOPT_RETURNTRANSFER => true, CURLOPT_ENCODING => "", CURLOPT_MAXREDIRS => 10, CURLOPT_TIMEOUT => 30, CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1, CURLOPT_CUSTOMREQUEST => "GET", CURLOPT_HTTPHEADER => array( "accept: application/json", "cookie: JSESSIONID = $jsessionid;"     ), )); $response = curl_exec($curl); $err = curl_error($curl); curl_close($curl); if ($err) { echo "cURL Error #:" . $err; } $curl = curl_init(); curl_setopt_array($curl, array( CURLOPT_URL => "https://my.zipato.com/zipato-web/v2/box/reboot/$serial";, CURLOPT_RETURNTRANSFER => true, CURLOPT_ENCODING => "", CURLOPT_MAXREDIRS => 10, CURLOPT_TIMEOUT => 30, CURLOPT_HTTP_VERSION => CURL_HTTP_VERSION_1_1, CURLOPT_CUSTOMREQUEST => "GET", CURLOPT_HTTPHEADER => array( "accept: application/json", "cookie: JSESSIONID = $jsessionid;" ), )); $response = curl_exec($curl); $err = curl_error($curl); curl_close($curl); if ($err) { echo "cURL Error #:" . $err; } else { echo 'success'; } ?>
If yes, can you give some guidance if not the full code?
I'm using ZipaTile as room thermostat (and lights, Sonos, etc. UI ), but sometimes it fails to send temperature data. The idea is to check periodically the group update time from resident script, and if it is to long issue a reboot command.
Thanks, Z
Try this:
username = 'xxx@xxx.xxx' password = 'xxx' serial = 'xxx' https = require('ssl.https') ltn12 = require('ltn12') sha1 = require('encdec').sha1 json = require('json') function dorequest(url, headers)   local tbl = {}   local res, err = https.request({     url = url,     headers = headers,     sink = ltn12.sink.table(tbl)   })   if res then     return table.concat(tbl)   else     return nil, err   end end res, err = dorequest('https://my.zipato.com/zipato-web/v2/user/init') log('init', res, err) if res then   data = json.decode(res)   password = sha1(password)   token = sha1(data.nonce .. password)   headers = {     ['accept'] = 'application/json',     ['cookie'] = 'JSESSIONID=' .. data.jsessionid .. ';',   }   url = 'https://my.zipato.com/zipato-web/v2/user/login?token=' .. token .. '&username=' .. username   res, err = dorequest(url, headers)   log('login', res, err)   if res then     url = 'https://my.zipato.com/zipato-web/v2/box/reboot/' .. serial     res, err = dorequest(url, headers)     log('reboot', res, err)   end end
Thanks Admin,
It works as advertised Smile
I´ve tried to traslate this code to LM with your example but something is wrong.
Can anyone help me?
<?php
// set variables
$queryUrl = "http://api.kairos.com/detect";
$imageObject = '{"image":"YOUR_IMAGE_URL"}';
$APP_ID = "YOUR_APP_ID";
$APP_KEY = "YOUR_APP_KEY";
$request = curl_init($queryUrl);
// set curl options
curl_setopt($request, CURLOPT_POST, true);
curl_setopt($request,CURLOPT_POSTFIELDS, $imageObject);
curl_setopt($request, CURLOPT_HTTPHEADER, array(
"Content-type: application/json",
"app_id:" . $APP_ID,
"app_key:" . $APP_KEY
curl_setopt($request, CURLOPT_RETURNTRANSFER, true);
$response = curl_exec($request);
// show the API response
echo $response;
// close the session
curl_close($request);
http = require('socket.http') ltn12 = require('ltn12') json = require('json') function dorequest(url, headers, data)   local resp = {}   headers['Content-Length'] = #data   local res, err = http.request({     url = url,     method = 'POST',     headers = headers,     sink = ltn12.sink.table(resp),     source = ltn12.source.string(data)   })   if res then     return table.concat(resp)   else     return nil, err   end end url = 'http://api.kairos.com/detect' imageurl = 'http://...' app_id = 'YOUR_APP_ID' app_key = 'YOUR_APP_KEY' headers = {   ['Content-Type'] = 'application/json',   ['app_id'] = app_id,   ['app_key'] = app_key, } data = json.encode({   ['image'] = imageurl }) res, err = dorequest(url, headers, data) log(res, err)
Thanks!!
It works fine!
