Help decoding JSON data from socket.http.request
Dear All,
I'm trying to retrieve consumption info from an "Ecocompteur" box from Legrand with the following code, but it does not work as expected.
The returned Content-Type is "text/plain" while it should be "application/json", so the json.decode function does not work.
Is there another way to retrieve data values from the returned "json" data ?
Thanks in advance
123456789101112131415
Accessing "http://192.168.1.xx/inst.json" give this data in return : {    "data1":27.000000,    "data2":0.000000,    "data3":0.000000,    "data4":0.000000,    "data5":0.000000,    "data6":0.000000,    "data6m3":0.000000,    "data7":0.000000,    "data7m3":0.000000,    "heure":22,    "minute":5 }
12345678910111213141516171819202122
require 'ltn12' require 'socket.http' json = require("json") local request_url = "http://192.168.1.xx/inst.json" local response_body = {} local body, code, hdrs, stat = socket.http.request   {     url = request_url;     sink = ltn12.sink.table(response_body);   } log (body, code, hdrs, stat) -- local response_decode = json.decode(table.concat (response_body)) log (response_body) -- local data1 = response_decode.data1 -- local data2 = response_decode.data2 ...
Here is the log output :
123456789101112131415161718192021222324252627282930313233343536373839404142434445
Ecocompteur 01.11.2017 20:33:54 * arg: 1  * number: 1 * arg: 2  * number: 200 * arg: 3  * table:   [server]    * string: lwip/3.0   [content-type]    * string: text/plain * arg: 4  * string: HTTP/1.0 200 OK Ecocompteur 01.11.2017 20:33:54 * string: {    "data1":35.000000,    "data2":0.000000,    "data3":1.000000,    "data4":0.000000,    "data5":0.000000,    "data6":0.000000,    "data6m3":0.000000,    "data7":0.000000,    "data7m3":0.000000,    "heure":20,    "minute":33 }HTTP/1.0 200 OK Server: lwip/3.0 Content-Type: text/plain {    "data1":35.000000,    "data2":0.000000,    "data3":1.000000,    "data4":0.000000,    "data5":0.000000,    "data6":0.000000,    "data6m3":0.000000,    "data7":0.000000,    "data7m3":0.000000,    "heure":20,    "minute":33 }
Try  this:
if type(response_body) == 'table' then   data = json.pdecode(table.concat(response_body)) else   data = json.pdecode(response_body) end log(data)
Try running this then post both log entries. What it looks like is that the response is incorrect. JSON functions expect valid input which does not have "Content-Type" set anywhere so it's not the problem.
require('json') require('socket.http') url = 'http://192.168.1.xx/inst.json' data = socket.http.request(url) log(data) log(json.pdecode(data))
(02.11.2017, 06:55)admin Wrote: Try running this then post both log entries. What it looks like is that the response is incorrect. JSON functions expect valid input which does not have "Content-Type" set anywhere so it's not the problem.
Here is the log entries I got :
Ecocompteur 02.11.2017 07:58:47 * string: {    "data1":195.000000,    "data2":0.000000,    "data3":0.000000,    "data4":173.000000,    "data5":0.000000,    "data6":0.000000,    "data6m3":0.000000,    "data7":0.000000,    "data7m3":0.000000,    "heure":7,    "minute":58 }HTTP/1.0 200 OK Server: lwip/3.0 Content-Type: text/plain {    "data1":195.000000,    "data2":0.000000,    "data3":0.000000,    "data4":173.000000,    "data5":0.000000,    "data6":0.000000,    "data6m3":0.000000,    "data7":0.000000,    "data7m3":0.000000,    "heure":7,    "minute":58 } Ecocompteur 02.11.2017 07:58:47 * arg: 1  * nil * arg: 2  * string: Expected the end but found invalid token at character 253
(I PM you more info)
Thx
(01.11.2017, 21:50)Erwin van der Zwart Wrote: Hi,
Try  this:
Thx Erwin, but it does not work.
Here is the log entry :
Ecocompteur 02.11.2017 08:33:27
* nil
Strange, I've tested it with your access details and it works correctly. Which firmware version are you running?
Can you also try running request like this?
sock = require('socket').tcp() sock:settimeout(5) res, err = sock:connect('192.168.1.xx', 80) if res then   sock:send('GET /inst.json HTTP/1.1\r\n\r\n')   res = sock:receive('*a')   log(res)   if res then     p, e = res:find('\r\n\r\n', 1, true)     if e then       data = res:sub(e + 1)       data = require('json').pdecode(data)       log(data)     end   end end
(02.11.2017, 07:44)admin Wrote: Strange, I've tested it with your access details and it works correctly. Which firmware version are you running?
1Version 2: 20170620
It should be the last I think ?
I'll try again ..
(02.11.2017, 07:48)admin Wrote: Can you also try running request like this?
Thanks, it works perfectly !
