01.11.2017, 21:13
Dear All,
I'm trying to retrieve consumption info from an "Ecocompteur" box from Legrand with the following code, but it does not work as expected.
The returned Content-Type is "text/plain" while it should be "application/json", so the json.decode function does not work.
Is there another way to retrieve data values from the returned "json" data ?
Thanks in advance
Here is the log output :
Thanks in advance
Accessing "http://192.168.1.xx/inst.json" give this data in return :
"data1":27.000000,
"data2":0.000000,
"data3":0.000000,
"data4":0.000000,
"data5":0.000000,
"data6":0.000000,
"data6m3":0.000000,
"data7":0.000000,
"data7m3":0.000000,
"heure":22,
"minute":5
}Code:
require 'ltn12'
require 'socket.http'
json = require("json")
local request_url = "http://192.168.1.xx/inst.json"
local response_body = {}
local body, code, hdrs, stat = socket.http.request
url = request_url;
sink = ltn12.sink.table(response_body);
log (body, code, hdrs, stat)
-- local response_decode = json.decode(table.concat (response_body))
log (response_body)
-- local data1 = response_decode.data1
-- local data2 = response_decode.data2
...Here is the log output :
Ecocompteur 01.11.2017 20:33:54
* arg: 1
* number: 1
* arg: 2
* number: 200
* arg: 3
* table:
[server]
* string: lwip/3.0
[content-type]
* string: text/plain
* arg: 4
* string: HTTP/1.0 200 OK
* string: {
"data1":35.000000,
"data2":0.000000,
"data3":1.000000,
"data4":0.000000,
"data5":0.000000,
"data6":0.000000,
"data6m3":0.000000,
"data7":0.000000,
"data7m3":0.000000,
"heure":20,
"minute":33
}HTTP/1.0 200 OK
Server: lwip/3.0
Content-Type: text/plain
"data1":35.000000,
"data2":0.000000,
"data3":1.000000,
"data4":0.000000,
"data5":0.000000,
"data6":0.000000,
"data6m3":0.000000,
"data7":0.000000,
"data7m3":0.000000,
"heure":20,
"minute":33
