Send e-mail
I needed to send an email when an event with a group address occurs. Does anyone have an example?
Just use the build in mail function and trigger it as event based script:
-- make sure mail settings are set in common functions library before using this function subject = 'E-mail test' message = 'Testing e-mail' mail('user@example.com', subject, message)
I need to send a value from storage by email, someone has an example?
For event value you can use an event script:
value = event.getvalue() subject = 'E-mail test' message = 'Event value is ' .. tostring(value) mail('user@example.com', subject, message)
For storage value you need a scheduled script. But, if you want to send a value on each storage value change you should use a virtual object instead because you cannot attach an event script to storage changes.
value = storage.get('myvalue') subject = 'E-mail test' message = 'Storage value is ' .. tostring(value) mail('user@example.com', subject, message)
Thank you very much
Hello guys!
A little bit of help here..
I have cycling send from a GA that comes from a generator. Can we adjust the code to send the email only if the GA changes it’s state. So an email with subject ‘Generator On’ will be sent when the GA is 1 and an email with subject ‘Generator Off’ will be sent when the GA is 0.
Thank you in advance!!
Something like that would do, event script
123456789101112131415
value = event.getvalue() mydata = storage.get('myobjectdata', 2) if value then   if value ~= mydata then     --emial for on   end else     if value ~= mydata then    --email for off   end end  storage.set('myobjectdata', value)
As always… your script works like a charm!!!!
Thank you very much!!
