25.01.2018, 08:11
there is some script to go back from the specific page of schedules to a visualization page?
schedule page
25.01.2018, 08:11
25.01.2018, 11:55
Add schedule on visualization via frame. Then you can use your menu for navigation. BR
25.01.2018, 12:14
26.01.2018, 10:31
(25.01.2018, 11:55)Daniel. Wrote: Hi Hi Daniel I've hundreds of schedulers. Do you have any idea how to pass scheduler ID through a frame? I don't want to create 100+ additional windows with just one frame. I believe there must be way in javascript etc.
You can check a current plan Id with currentPlanId and change the src of which is on this plan:
<iframe border="0" src="/scada-vis/trends?id=24" width="984" height="464" frameborder="0"></iframe> But all of this you can do with Custom Javascript. You can for example add some Additional class e.g. "Kitchen_Temperature" to the object which is connected to universal widget and then based on this class you can change the src of this widget. I have similar issue so maybe I will try to create something like this
This code is for using one widget page with an iframe for showing trends and schedulers:
Code: // Change src of widget and have 1 widget for every trend and scheduler in visualisationHow to use it: 1. Create a widget 2. Add the iframe to the widget and add to it Additional class "trends_n_schedulers" 3. Add above Javascript code to your Custom Javascript and edit trendsMap and schedulersMap tables
06.02.2018, 19:04
Thank you it works.
But it doesn't work in touch visu. Why there's this row in your code? It disables loading of the inner page in touch visu. if (!$('body').hasClass('usermode')) { return; }
06.02.2018, 19:15
This row is for using this script only in main visualisation and not anywhere else so probably this is the answer for your question
But i you delete it it would be executed also on other places like Trends, Schedulers pages. But if you will delete it it would work.
29.01.2019, 14:24
(28.01.2018, 16:01)buuuudzik Wrote: This code is for using one widget page with an iframe for showing trends and schedulers: This row Code: let {type, className, query} = mapping[i];Working solution is Code: let type = mapping[i].type;
