Object logging and exporting
In the manual there is a warning that excessive object logging degrades performance.
Is the same true for object exporting?
No, when you export you ether create BACnet object or webservice but nothing is saved. When you log objects then x amount of data is saved each time tellegram is received.
For sure whey you export lots of objects cpu will go up but this this is related to everything.
How often are logged values written? Is it immediately or in 30 minutes cycles like trends etc?
Thank you
(06.02.2018, 14:22)Thomas Wrote: Hi
Thank you
in 30 min. This would kill card immediately...
