Restore backup failed
Hi, I try to restore backup from Spacelynk v2.0 to another spacelynk v2.1 and several backup failed to restore (invalid).
Do you know if there is a trick/fle to modify in backup to reimport easily all my backup to different customer project.
I have one spacelynk and one homelynk as demo server for customer that i use to present and develop before deploying it to customer building.
SE ECO EXPERT
I try with several different backup file and still the same error (Backup file is invalid)
I also try to reset the Spacelynk without sucess
I can open the archive file.
SE ECO EXPERT
Have you made any changes to the backup file using 7Zip or other utility?
(09.02.2018, 11:17)admin Wrote: Have you made any changes to the backup file using 7Zip or other utility?
none ! I tried to restore at least 5 different project without any sucess !
Lots of them was made on Spacelynk and homelynk 2.0.1 firmware.
I can't restore it on my Spacelynk 2.1.1 firmware ! Any of them are accepted !
The fun point is that partial program are imported (but still message invalid file), but looks like some picture are missing.
SE ECO EXPERT
Can you open the back-up with a compressed folder application like 7Zip? What is the size of your backup? Is it a couple of Kb's? Could be corrupt backup-up sets..
(09.02.2018, 11:44)Erwin van der Zwart Wrote: Hi,
Thank for your help.
No backup are ok ! I can open it, I used them several time before (like template for me). And I try different project to test.
The backup are at least 4MO
I sent you the link and the backup example.
It's a test server, feel free to do any action on it without risk.
SE ECO EXPERT
Did you try this backup on different device ?
I just imported your backup into my W4K without issues, so your back-up is valid.. and your project/work is save (:
Now we need to check why you can't upload it in yours..
(09.02.2018, 11:56)Erwin van der Zwart Wrote: Hi,
just think about disabling the script in resident about the dns update or the customer would not have access to his server again but to yours ;-)
(09.02.2018, 11:53)Daniel. Wrote: Hi
yes David, the backup is Ok !
In the past I used to import backup from Spacelynk to Homelynk, from Homelynk to Sapcelynk, from different version of firmware... without issue. I hope that it will continue like this because I have several backup I used as template for different customer project before deploying it in their building !
SE ECO EXPERT
I just uploaded the backup into your device without issues..
Can you clear browser chache, try with disabled virus scanner or use another browser / pc to test yourself?
(09.02.2018, 12:25)Erwin van der Zwart Wrote: Hi,
ok looks like it's a cache problem after upgrading the firmware from 2.1.0 to 2.1.1 and not refresh my browser cache
Thanks for help !
SE ECO EXPERT
