Updated version of Netatmo script with HTTPS (http is not allowed by netatmo anymore)
Task
How to get my Netatmo weather station readings into my KNX network using LogicMachine?
Things to prepare in advance
V2
v1
Use the function in your programs
Either in Event-based, Scheduled or Resident script run the function by command refresh_netatmo().
example : a scheduled script that run every minute with the content :
Matthieu
Task
- Buy Netatmo weather station
- Create a private app at http://dev.netatmo.com
- Add the following function in Common Functions or User Library
- Fill in the script with client_id, client_secret, username and password
- Rename object names with your own objects
- Rename module names to match configuration in Netatmo
V2
require 'ltn12'
require 'socket.http'
json = require("json")
https = require 'ssl.https'
function refresh_netatmo()
local netatmo_debug = true
local client_id = "xxx"
local client_secret = "xxx"
local username = "xxx"
local password = "xxx"
local scope = "read_station"
-- optional device_id
local device_id = "xxx"
local request_token_url = "https://api.netatmo.net/oauth2/token"
local request_device_list = "https://api.netatmo.net/api/devicelist"
local response_body = { }
local export_data = {}
if (netatmo_debug) then
alert("netatmo start")
local request_body = "grant_type=password&client_id=" .. client_id .."&client_secret=" .. client_secret .. "&username=" .. username .. "&password=" .. password .. "&scope=" .. scope
local body, code, hdrs, stat = https.request
url = request_token_url;
method = "POST";
headers =
["Content-Type"] = "application/x-www-form-urlencoded";
["Content-Length"] = #request_body;
source = ltn12.source.string(request_body);
sink = ltn12.sink.table(response_body);
if (code ~= 200) then
alert("netatmo auth error : "..tostring(code)..","..tostring(body))
return
local response_decode = json.decode(table.concat(response_body))
local access_token = response_decode.access_token
alert("netatmo token %s",access_token)
-- request for all devices
local request_body = "access_token=" .. access_token .. "&app_type=app_station"
-- request to limit to only one device :
-- local request_body = "access_token=" .. access_token .. "&app_type=app_station&device_id=" .. device_id
url = request_device_list;
method = "POST";
headers =
alert("netatmo devicelist error : "..tostring(code)..","..tostring(body))
return
-- Main module
alert("netatmo main module")
grp.write("netatmo temperature interieure",response_decode.body.devices[1].dashboard_data.Temperature,dt.float16)
grp.write("netatmo humidite interieure",response_decode.body.devices[1].dashboard_data.Humidity,dt.scale)
grp.write("netatmo pression",response_decode.body.devices[1].dashboard_data.Pressure,dt.uint16)
grp.write("netatmo CO2",response_decode.body.devices[1].dashboard_data.CO2,dt.float16)
grp.write("netatmo sonometre",response_decode.body.devices[1].dashboard_data.Noise,dt.uint8)
grp.write("netatmo temperature interieure minimum",response_decode.body.devices[1].dashboard_data.min_temp,dt.float16)
grp.write("netatmo temperature interieure maximum",response_decode.body.devices[1].dashboard_data.max_temp,dt.float16)
grp.write("netatmo pression absolue",response_decode.body.devices[1].dashboard_data.AbsolutePressure,dt.uint16)
grp.write("netatmo salon temperature",response_decode.body.devices[1].dashboard_data.Temperature,dt.float16)
grp.write("netatmo salon humidite",response_decode.body.devices[1].dashboard_data.Humidity,dt.scale)
grp.write("netatmo salon CO2",response_decode.body.devices[1].dashboard_data.CO2,dt.uint16)
-- search for additional modules by name
for index, value in ipairs(response_decode.body.modules) do
alert("netatmo module " .. tostring(index) .. ":" .. tostring(value.module_name))
if (value.module_name == "Pluviomètre") then
alert("netatmo module match pluviometre")
grp.write("netatmo pluviometre",value.dashboard_data.Rain,dt.float16)
grp.write("netatmo pluviometre 1h",value.dashboard_data.sum_rain_1,dt.float16)
grp.write("netatmo pluviometre 24h",value.dashboard_data.sum_rain_24,dt.float16)
elseif (value.module_name == "Extérieur") then
alert("netatmo module match exterieur")
grp.write("netatmo temperature exterieure",value.dashboard_data.Temperature,dt.float16)
grp.write("netatmo humidite exterieure",value.dashboard_data.Humidity,dt.float16)
grp.write("netatmo temperature exterieure minimum",value.dashboard_data.min_temp,dt.float16)
grp.write("netatmo temperature exterieure maximum",value.dashboard_data.max_temp,dt.float16)
elseif (value.module_name == "Chambre") then
alert("netatmo module match Chambre")
grp.write("netatmo chambre temperature",value.dashboard_data.Temperature,dt.float16)
grp.write("netatmo chambre CO2",value.dashboard_data.CO2,dt.float16)
grp.write("netatmo chambre humidite",value.dashboard_data.Humidity,dt.scale)
elseif (value.module_name == "Bureau") then
alert("netatmo module match Bureau")
grp.write("netatmo bureau temperature",value.dashboard_data.Temperature,dt.float16)
grp.write("netatmo bureau CO2",value.dashboard_data.CO2,dt.float16)
grp.write("netatmo bureau humidite",value.dashboard_data.Humidity,dt.scale)
elseif (value.module_name == "Studio") then
alert("netatmo module match Studio")
grp.write("netatmo studio temperature",value.dashboard_data.Temperature,dt.float16)
grp.write("netatmo studio CO2",value.dashboard_data.CO2,dt.float16)
grp.write("netatmo studio humidite",value.dashboard_data.Humidity,dt.scale)
alert("netatmo end")
endv1
require 'ltn12'
local netatmo_debug = false
local client_id = ""
local client_secret = ""
local username = ""
local password = ""
-- optional
--local device_id = ""
method = "POST";
headers =
alert("netatmo auth error")
error("netatmo auth error : "..tostring(code)..","..tostring(body))
return
-- to limit to only one device :
method = "POST";
headers =
error("netatmo devicelist error")
return
-- Module int
alert("netatmo device 1")
grp.write("Netatmo Température intérieure",response_decode.body.devices[1].dashboard_data.Temperature,dt.float16)
grp.write("Netatmo Humidité intérieure",response_decode.body.devices[1].dashboard_data.Humidity,dt.scale)
grp.write("Netatmo Pression",response_decode.body.devices[1].dashboard_data.Pressure,dt.uint16)
grp.write("Netatmo CO2",response_decode.body.devices[1].dashboard_data.CO2,dt.uint16)
grp.write("Netatmo Sonomètre",response_decode.body.devices[1].dashboard_data.Noise,dt.uint8)
grp.write("Netatmo Température intérieure minimum",response_decode.body.devices[1].dashboard_data.min_temp,dt.float16)
grp.write("Netatmo Température intérieure maximum",response_decode.body.devices[1].dashboard_data.max_temp,dt.float16)
grp.write("Netatmo Pression absolue",response_decode.body.devices[1].dashboard_data.AbsolutePressure,dt.uint16)
-- Module ext
alert("netatmo module 1")
grp.write("Netatmo Température extérieure",response_decode.body.modules[1].dashboard_data.Temperature,dt.float16)
grp.write("Netatmo Humidité extérieure",response_decode.body.modules[1].dashboard_data.Humidity,dt.float16)
grp.write("Netatmo Température extérieure minimum",response_decode.body.modules[1].dashboard_data.min_temp,dt.float16)
grp.write("Netatmo Température extérieure maximum",response_decode.body.modules[1].dashboard_data.max_temp,dt.float16)
-- Module Pluvio
alert("netatmo module 2")
grp.write("Netatmo Pluviomètre",response_decode.body.modules[2].dashboard_data.Rain,dt.float16)
grp.write("Netatmo Pluviomètre 1h",response_decode.body.modules[2].dashboard_data.sum_rain_1,dt.float16)
grp.write("Netatmo Pluviomètre 24h",response_decode.body.modules[2].dashboard_data.sum_rain_24,dt.float16)
endUse the function in your programs
refresh_netatmo()Matthieu
