Threads: 94
(10.03.2018, 17:16) buuuudzik Wrote: (10.03.2018, 17:14) Domoticatorino Wrote: It is a Schneider HL 2.0.1
I mean updated version of above script I've adjusted it to be more universal, added new variables:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
valveStatesTag =
'circulation_pump'
pumpGA =
'1/1/10'
openingValveTime =
300
minInterval =
30
opened ,
firstTimestamp =
false ,
valveStates =
grp.tag (
valveStatesTag )
for v =
1 , #
valveStates ,
1 do
valveState =
valveStates [
v ]
if valveState.value then
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
valveState.updatetime then firstTimestamp =
valveState.updatetime end
firstTimestamp =
if opened then
fullyOpened = (
os.microtime () -
firstTimestamp ) >=
openingValveTime
if fullyOpened then
grp.checkwrite (
pumpGA ,
true )
nextCalculationAfter =
minInterval
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
1 - (
os.microtime () -
firstTimestamp )
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
log (
'Next calculation after: ' ..
nextCalculationAfter ..
's.' )
os.sleep (
nextCalculationAfter )
No, it does not work.
there is not any mistake and any error log. Is there the opportunity to have a debug for lua?
Threads: 161
What are your settings? It is resident script 0s? Did you tried disable and enable script? Did you add the tag to valves? Do you changed the GA for pump?
When script start it should log such message in the Logs:
Circulation pump calculation 10.03.2018 18 :
33 :
49
string :
Next calculation after :
293s.
Done is better than perfect
Threads: 94
It is a resident script set at 60 seconds.
Obviously I add tag and change address of pump. In the log I read "next calculation after" but pumps does not start.
Threads: 161
(10.03.2018, 18:36) Domoticatorino Wrote: It is a resident script set at 60 seconds.
Please change the time to 0, update script to the newest version, disable and enable it and it must work.
I've checked it and all works perfect. You can also comment this line with log.
Threads: 94
Thank you very much. It works!!
Great
Threads: 94
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
valveStatesTagEstate =
'pompa_circolazione_giorno_estate'
valveStatesTagInverno =
'pompa_circolazione_giorno_inverno'
pumpGA =
'2/0/1'
openingValveTime =
60
minInterval =
30
opened ,
firstTimestamp =
false ,
if stagione ==
false then
valveStatesEstate =
grp.tag (
valveStatesTagEstate )
for v =
1 , #
valveStatesEstate ,
1 do
valveStateEstate =
valveStatesEstate [
v ]
if valveStateEstate.value then
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
valveStateEstate.updatetime then firstTimestamp =
valveStateEstate.updatetime end
firstTimestamp =
valveStatesInverno =
grp.tag (
valveStatesTagInverno )
for v =
1 , #
valveStatesInverno ,
1 do
valveStateInverno =
valveStatesInverno [
v ]
if valveStateInverno.value then
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
valveStateInverno.updatetime then firstTimestamp =
valveStateInverno.updatetime end
firstTimestamp =
if opened then
fullyOpened = (
os.microtime () -
firstTimestamp ) >=
openingValveTime
if fullyOpened then
grp.checkwrite (
pumpGA ,
true )
minInterval
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
1 - (
os.microtime () -
firstTimestamp )
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
log (
valveStatesEstate )
os.sleep (
In your opinion what is wrong in this script above. I add a condition to separate winter condition from summer condition.
I log variable log(valveStatesEstate) but the result is nil. Objects tags are correct and in other 2 scripts (the same) everything works fine.
I cannot understand the reason why it does not working. I expect to read TRUE in log (valveStateEstate).
Thank you for your help.
Threads: 161
You are trying to log value 'ValveStatesEstate' but you hasn't defined stagione so stagione equals nil so else condition is executed.
But generally when you extend this script maybe better would be create some function and do script more elastic also for the future
See below (but still you must define stagione!):
pumpGA =
'2/0/1'
openingValveTime =
60
minInterval =
30
opened ,
firstTimestamp =
false ,
function getParamsFromValveStates (
valvesTag )
local valveStates =
grp.tag (
valveStatesTag )
for v =
1 , #
valveStates ,
1 do
valveState =
valveStates [
v ]
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
firstTimestamp =
return opened ,
firstTimestamp
if not stagione then opened ,
firstTimestamp =
else opened ,
firstTimestamp =
if opened then
fullyOpened = (
os.microtime () -
firstTimestamp ) >=
openingValveTime
if fullyOpened then
grp.checkwrite (
pumpGA ,
true )
minInterval
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
1 - (
os.microtime () -
firstTimestamp )
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
os.sleep (
Threads: 94
(24.04.2018, 17:03) buuuudzik Wrote: You are trying to log value 'ValveStatesEstate' but you hasn't defined stagione so stagione equals nil so else condition is executed.
pumpGA =
'2/0/1'
openingValveTime =
60
minInterval =
30
opened ,
firstTimestamp =
false ,
valvesTag )
local valveStates =
grp.tag (
valveStatesTag )
for v =
1 , #
valveStates ,
1 do
valveState =
valveStates [
v ]
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
firstTimestamp =
return opened ,
firstTimestamp
firstTimestamp =
else opened ,
firstTimestamp =
if opened then
fullyOpened = (
os.microtime () -
firstTimestamp ) >=
openingValveTime
if fullyOpened then
grp.checkwrite (
pumpGA ,
true )
minInterval
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
1 - (
os.microtime () -
firstTimestamp )
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
os.sleep (
Thank you very much...stupid mistake!! I have to hire you
Threads: 161
Nice
Threads: 94
How long do you code Lua?
Threads: 161
25.04.2018, 02:42
(This post was last modified: 25.04.2018, 02:44 by buuuudzik .)
(24.04.2018, 23:24) ODomoticatorino Wrote: How long do you code Lua?
3-4 years with Logic Machine. Sometimes less sometimes more. But I’ve asked a lot of questions also on this forum
Now I like more Javascript than Lua and LM would be for me perfect with modern JS instead the Lua
Threads: 94
Wow cool. I am using LM for 2 years and I hope to improve my skills in coding.
You are very good. Thanks.
Threads: 161
25.04.2018, 10:57
(This post was last modified: 25.04.2018, 10:57 by buuuudzik .)
For sure, be patient, try and ask
Threads: 94
Hi there,
I have a big problem with the script below. Please consider that I have 3 same script (obviosly with different varables) and everyting works fine. The one below does not work anymore.
I have seen in the obkect list that last update of group address 2/0/2 was dated 16th of September. The other correctly dated today. I cannot understand the reason why it does not work anymore. And nothing changed.
I tried to delate scritp and redo it without success. I tried to do again object 2/0/2 without success. Nothing group address 2/0/2 never update. Could you help me please?
'pompa_circolazione_mansarda_estate'
'pompa_circolazione_mansarda_inverno'
stagione =
grp.getvalue (
'2/0/100' )
pumpGA =
'2/0/2'
openingValveTime =
60
minInterval =
30
opened ,
firstTimestamp =
false ,
if stagione ==
false then
valveStatesEstate =
grp.tag (
for v =
1 , #
valveStatesEstate ,
1 do
valveStateEstate =
valveStatesEstate [
v ]
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
firstTimestamp =
grp.tag (
for v =
1 , #
1 do
valveStateInverno =
v ]
opened =
true
if firstTimestamp >
0 then
if firstTimestamp >
firstTimestamp =
if opened then
fullyOpened = (
os.microtime () -
firstTimestamp ) >=
openingValveTime
if fullyOpened then
grp.checkwrite (
pumpGA ,
true )
minInterval
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
1 - (
os.microtime () -
firstTimestamp )
grp.checkwrite (
pumpGA ,
false )
openingValveTime +
os.sleep (
Threads: 43
Add some logging to your script before any grp.checkwrite call. Since it uses grp.checkwrite there won't be any value sent unless it changes.
Threads: 94
Ok, log of which variable? Thanks
Threads: 43
Add this before os.sleep, this will give some info where the script is going:
log (
stagione ,
opened ,
os.time (),
firstTimestamp )
Threads: 161
Please:
Maybe you have some error in tags.
Threads: 94
(24.10.2018, 12:20) buuuudzik Wrote: Please:
Here below the log:
Tesy_pompa_circolazione_mansarda 24.10.2018 14:36:47
* table:
[1]
* table:
[export]
* number: 0
[disablelog]
* number: 1
[tagcache]
* string: clima, pompa_circolazione_mansarda_inverno, pompa_circolazione_mansarda_estate
[datahex]
* string: 00
[units]
* string:
[value]
* bool: false
[comment]
* string:
[updatetime]
* number: 1540384570
[datatype]
* number: 1009
[address]
* string: 2/0/107
[id]
* number: 4203
[data]
* bool: false
[highpriolog]
* number: 0
[pollinterval]
* string:
[readoninit]
* number: 0
[name]
* string: T7 FB Elettrovalvola pavimento mansarda
[decoded]
* bool: true
[size=undefined]
* arg: 1
* bool: true
* arg: 2
* bool: false
* arg: 3
* number: 1540384607
* arg: 4
* number: 0[/size]
Threads: 43
The last script you've posted does not have valveStates variable anywhere, please post the latest version that you are using. Also, try turning 2/0/107 on.
