SONOS
hello .
i use this script http://openrb.com/sonos-control-from-logic-machine/ for control sonos .
i have some questions...
1) i must to creat an address 1 byte for control or ascii?
2) how is possibole to control 2or more sonos player ?
3) how is possibole to start play my favorite ply list from spotify ?
is possibole to upload an example on the http://4n.lv:7999/apps/?
thank you in advance.
please can you help me.......
You are now using a standard UpnP script, why don't you use the Sonos App and use the build in API of the app, it supports grouping etc.
Read this article for commands: https://forum.logicmachine.net/showthrea...44#pid2244
please is very easy to help me because I am a beginner with them
the ip ip from wiser is 192.168.1.50
my sonos ip is 192.168.1.7 and 192.168.1.8
-- Load modules
require('json')
require('socket.http')
-- Set timout
socket.http.TIMEOUT = 5
-- Read IP address from controller
data = io.readproc('if-json')
data = json.decode(data)
ip = data.eth0.inetaddr
-- Set SONOS name
Sonos_Player_Name = 'dining'
-- Get event value
value = event.getvalue()
-- Set stepsize volume
Volume_Step = 10
-- Set Action
if value == 101 then
    Sonos_Action = 'play'
elseif value == 102 then
    Sonos_Action = 'stop'
elseif value == 103 then
    Sonos_Action = 'next'
elseif value == 104 then
    Sonos_Action = 'previous'
elseif value == 105 then
    Sonos_Action = 'mute'
elseif value == 106 then
    Sonos_Action = 'unmute'
elseif value == 107 then
    Sonos_Action = 'setvolumeup'
 Volume_Step = Volume_Step or 10
elseif value == 108 then
 Sonos_Action = 'setvolumedown'
 action = 'none'
-- Execute action on value 0 to 100
if value >= 0 and value <= 100 then
 local reply = socket.http.request('http://'192.168.1.50'/apps/data/sonos/sonos.lp?action=setvolume&name=' .. dining.. '&volume=' .. value .. '')
-- Execute action on value 101 to 106
if value >= 101 and value <= 106 then
    local reply = socket.http.request('http://'192.168.1.50'/apps/data/sonos/sonos.lp?action=' .. Sonos_Action .. '&name=' ..dining.. '')
-- Execute action on value 107 to 108
if value >= 107 and value <= 108 then
    local reply = socket.http.request('http://'192.168.1.50'/apps/data/sonos/sonos.lp?action=' .. Sonos_Action .. '&name=' ..dining .. '&step=' .. Volume_Step .. '')
-- Execute action on value 255 (Feedback)
if value == 255 then
    local reply = socket.http.request('http://'192.168.1.50'/apps/data/sonos/sonos.lp?action=getextendedstate&name=' ..dining.. '&createbaseimg=true')
 reply = json.pdecode(reply)
 if reply then
     local current_volume = reply[1].volume
     local current_mutestate = reply[2].mute
   local current_crossfadestate = reply[3].crossfade
   local current_playmode = reply[4].playmode
   local current_transportmode = reply[5].transport
   local current_duration = reply[7].duration
   local current_playingtime = reply[8].playingtime
   local current_title = reply[9].tracktitle
   local current_artist = reply[10].creator
   local current_album = reply[11].album
   local current_albumart = reply[12].albumart
   local current_mediatype = reply[11].mediatype
You added the name dining as a variable in the URL so that will never work..
Try this first so you have a working sample, from there you can expand the script:
-- Load modules require('socket.http') -- Set timout socket.http.TIMEOUT = 5 -- Set SONOS name Sonos_Player_Name = 'dining'  -- Is this written exactly as you see in the Sonos App without capital etc? -- Get value for volume value = event.getvalue() -- 0 to 100 so set object to scale reply = socket.http.request('http://'192.168.1.50'/apps/data/sonos/sonos.lp?action=setvolume&name=' .. Sonos_Player_Name .. '&volume=' .. value .. '')
or by IP (i prever name as IP is DHCP and can change, name will never change automaticly)
-- Load modules require('socket.http') -- Set timout socket.http.TIMEOUT = 5 -- Set SONOS IP Sonos_Player_IP = '192.168.1.7' -- Get value for volume value = event.getvalue() -- 0 to 100 so set object to scale reply = socket.http.request('http://'192.168.1.50'/apps/data/sonos/sonos.lp?action=setvolume&ip=' .. Sonos_Player_IP .. '&volume=' .. value .. '')
PS: Be sure to have opened the Sonos app at least once so the players are scanned and listed in the controller with name and IP before using this script
first of all to thank you for the answer
i did the follow but do not work
-- Load modules
-- Set timout
-- Set SONOS IP
-- Get event value
Volume_Step = 10
-- Set Action
  action = 'none'
reply = socket.http.request('http://192.168.1.50/apps/data/sonos/sonos.lp?action=setvolume&ip= http://192.168.1.7 &volume= 10 ')-- Execute action on value 255 (Feedback)
    local reply = socket.http.request('http://192.168.1.50/apps/data/sonos/sonos.lp?action=play&ip= http://192.168.1.7 ')
  local reply = socket.http.request('http://192.168.1.50/apps/data/sonos/sonos.lp?action=stop&ip= http://192.168.1.7 ')
    local reply = socket.http.request('http://192.168.1.50/apps/data/sonos/sonos.lp?action=getextendedstate&ip= http://192.168.1.7 &createbaseimg=true')
  if reply then
It probably does not work because you have password enabled for apps. Create user with login sonos and password sonos123
Then create an event script mapped to 1-byte scale object:
Sonos_Player_IP = '192.168.1.7' value = event.getvalue() -- 0 to 100 so set object to scale http = require('socket.http') http.TIMEOUT = 5 reply = http.request('http://sonos:sonos123@127.0.0.1/apps/data/sonos/sonos.lp?action=setvolume&ip=' .. Sonos_Player_IP .. '&volume=' .. value)
If this still does not work, add this at the end of the script and post what you get in Logs tab:
log(reply)
It also does not work because there are multiple spaces in the URL (not allowed) and you have added http:// before the IP address, Sonos is not controlled over HTTP.
Please keep the URL as it is and only change IP address of the controller to the correct IP or 127.0.0.1 as admin's sample..
hi were i must to creat user? in my application on my phone ?
Event for sonos (1/1/1) 27.03.2018 15:03:47
* string: Access Denied
In User Access tab
(27.03.2018, 12:14)admin Wrote: In User Access tab
ok now i have that
Event for sonos (1/1/1) 27.03.2018 15:16:55
* string: true
This means that the request is working correctly. Does the volume change on your Sonos device?
(27.03.2018, 12:21)διαχειριστής Wrote: This means that the request is working correctly. Does the volume change on your Sonos device?
unfortunately no i use the follow
-- Load modules
-- Set timout
-- Set SONOS IP
reply = socket.http.request('http://admin:sonos123@192.168.1.50/apps/data/sonos/sonos.lp?action=setvolume&ip=192.168.1.7&volume=' ..value)
log(reply)
Please use the example that I've provided. You keep changing the code randomly and of course it's not working. In your case value variable is not defined.
(27.03.2018, 12:37)admin Wrote: Please use the example that I've provided. You keep changing the code randomly and of course it's not working. In your case value variable is not defined.
I'm sorry I'm a beginner with lua.
it change volume now.
how is posible to cotrolthe next commands from sonos?
thanks
Map this event script to 1-bit object. True/on = play, false/off = stop
Sonos_Player_IP = '192.168.1.7' value = event.getvalue() if value then   action = 'play' else   action = 'stop' end http = require('socket.http') http.TIMEOUT = 5 reply = http.request('http://sonos:sonos123@127.0.0.1/apps/data/sonos/sonos.lp?action=' .. action .. '&ip=' .. Sonos_Player_IP)
Did you know that basic sonos control you can do without any script?
Open app, pres + next to your player and add it. It will create objects in LM to control sonos. Just search your objects.
thank you very much for your help (invaluable) I understood it
Hi Daniel,
Now i know why you added that (:
(27.03.2018, 13:06)Daniel. Wrote: Hi
Is it possible somewhere to change the groupadresses this function creates? Seems like it start with the first available addresses...
thomas
