SOURCE ADDRESS
Hi:
I need to know the source address from an event.
I need it because it depends on where the event comes from, I will perform one task or another
it would be something like reading the result the value of the event, but in this case it would be from whom
value = event.getaddress()!!
value = event.src
log(value)
(19.04.2018, 13:48)Daniel. Wrote:
value = event.src
log(value)
The result is 'local' I need knx source address....
The result is local when you send telegram from LM. Send telegram from KNX and check again.
(19.04.2018, 14:08)Daniel. Wrote: The result is local when you send telegram from LM. Send telegram from KNX and check again.
Sorry , it's perfect.
