test if resident script running
It is possible to test whether a resident script is running?
Thanks,
Roger
(29.03.2018, 19:42)rocfusion Wrote: Hi,
Thanks,
Roger
From the manual on the left side of Script Editor:
script.status('scriptname')
Done is better than perfect
Perfect, thank you..
Hi buuuudzik,
I would like to link the status of a script to an object.
So, I use status script.status('scriptname') but in order to do that I have to create another script?
status = script.status ('Sequenza Irrigazione 1')
Value = status
grp.write('32/1/3', value)
But who trigger this script? So does it become a dangerous loop?
If you want to have such mapping better is to managing script by this object and not in other place.
So e.g. you have your script "Irrigating" and you use script.enable and script.disable only in event script for object e.g. 2/2/2 'Irrigating on/off'
You can also add something in Init script.
12345678910111213141516171819202122232425262728293031323334353637383940414243444546474849505152535455565758
mintimer = 1 -- minimum timer value in seconds maxtimer = 60 -- maximum timer value in seconds objects = {  {    output = '3/6/1',    timer = '3/6/101',  },  {    output = '3/6/2',    timer = '3/6/102',  },  {    output = '3/6/3',    timer = '3/6/103',  },  {    output = '3/6/4',    timer = '3/6/104',  },  {    output = '3/6/5',    timer = '3/6/105',  },  {    output = '3/6/6',    timer = '3/6/106',  },  {    output = '3/6/7',    timer = '3/6/107',  },  {    output = '3/6/8',    timer = '3/6/108',  } } function dosleep(obj)  local timer = grp.getvalue(obj)  timer = tonumber(timer)  if timer then    if timer < mintimer then      timer = mintimer    elseif timer > maxtimer then      timer = maxtimer    end    sleep(timer) -- conversione da secondi a minuti  end end for _, item in ipairs(objects) do  grp.write(item.output, true)  dosleep(item.timer)  grp.write(item.output, false) end
Let me show you. This above is a event scheduler which run when group 3/6/201 is triggered (true or false it does not matter)
If script status group is 32/1/3 do you mean insert this below in the same script above?
status = script.status('scriptname')
value = status
grp.write(32/1/3, value)
I did that. I use this instruction at the beginning of the script and at the end. Problem is that I never received false to group 32/1/3.
I hope you understand what you mean.
In this case actually you have object and now I see that you have some os.sleep. So you can do it like below:
scriptStatusGA = '32/1/3' grp.checkupdate(scriptStatusGA, true) -- YOUR SCRIPT grp.update(scriptStatusGA, false)
Great!! Thank you very much
