Scene trigger diffrent values
Hello I am new to scripting.
Knx
I need a script to send a couple of different 1byte values when a scene is trigged.
Need another script to do the same when a bit is trigged
You don't need a script to do that, just use the scene module that is default in the controller.
With script you can use this: (add as event based script to the scene object)
1234567891011121314
scenevalue = event.getvalue() if scenevalue == 1 then   grp.write('1/1/1', 10)   grp.write('1/1/2', true) -- binary   grp.write('1/1/3', 30)   os.sleep(2) -- delay if needed   grp.write('1/1/3', 40) elseif scenevalue == 2 then   grp.write('1/1/1', 50)   grp.write('1/1/2', false) -- binary   grp.write('1/1/3', 70)   os.sleep(1) -- delay if needed   grp.write('1/1/3', 80) end
For binary object:  (add as event based script to the binary object)
1234567891011121314
bitvalue = event.getvalue() if bitvalue == true then   grp.write('1/1/1', 10)   grp.write('1/1/2', true) -- binary   grp.write('1/1/3', 30)   os.sleep(2) -- delay if needed   grp.write('1/1/3', 40) else   grp.write('1/1/1', 50)   grp.write('1/1/2', false) -- binary   grp.write('1/1/3', 70)   os.sleep(1) -- delay if needed   grp.write('1/1/3', 80) end
Thank you.
You can do the same with scene tab. No scripting needed.
Hi Daniel,
That's what i wrote already, but i added the scripting for the option to add a delay, that's not possible (yet) with the scene tab (:
(11.06.2018, 22:04)Erwin van der Zwart Wrote: Hi Daniel,
Hello Erwin!!
It will be very handy if they install delay function in the scene tab!
They haven’t include it at the latest firmware update.
Do you know when they are gonna release it?
No i don’t know if it is still on the development list, i have not seen the updated version yet but admin should be able to tell...
I still have it on my wishlist so i will push for it (:
Sometime later this year Smile
