flasing
hello
does anyone knows how can flasing an object?
i used the following but did not work
if event.getvalue() == true then
  grp.write('1/2/16', flasing,2)
thanks in advance
Do you mean flashing or blinking?Wink
enableGA = '1/1/1' outputGA = '1/1/2' while grp.getvalue(enableGA) do   grp.write(outputGA, not grp.getvalue(outputGA))   os.sleep(1) end
But what you try to exactly achieve?
Done is better than perfect
(20.06.2018, 21:04)buuuudzik Wrote: Do you mean flashing or blinking?Wink
sorry blink i would like .
i tried it but not work
i would like to have an alarm blink in visu
a) You can use FBEditor app and Control -> Oscillator.
b) If you want create script then you can create Resident script with 2 seconds interval and inside it type (fill with your GAs):
enableGA = '1/1/1' outputGA = '1/1/2' if grp.getvalue(enableGA) then grp.write(outputGA, not grp.getvalue(outputGA)) end
If you are using event-based script for blinking you must be careful to not create infinite-loop.
Or find yourself nice GIF icon which flash and this will save you a lot of telegrams.
(21.06.2018, 07:54)Daniel. Wrote: Or find yourself nice GIF icon which flash and this will save you a lot of telegrams.
thanks for the help
