SSL communication
My LogicMachine communicates with second device via TCP (outgoing from LogicMachine) and HTTP (incoming to LogicMachine) protocols , I want to secure them with SSL. I can ensure SSL certificate with JavaScript in second device.
When I create socket it runs this code:
  local host, port = "IP address", portNO.
  local socket = require("socket")
  local tcp = assert(socket.tcp())
  tcp:connect(host, port)
--some code here
  tcp:send(value)
  tcp:close()
this is SSL unsecured, when I want to send value to server,
and when I receive data I create socket and send feedback data via
socket:send(value);
Is there some simple way to secure this communication with SSL in LogicMachine's Lua script?
Thank you!
Marek H.
Have a look here for HTTPS requests:
http://openrb.com/docs/lua.htm#ssl.https.request
If you need SSL for raw sockets, I can provide an example later.
(03.02.2016, 16:12)admin Wrote: Have a look here for HTTPS requests:
Thank you!
And I need also SSL for raw socket and copas.
Thanks alot Smile
For now we only have support for SSL/TLS in client mode, here's a short example. If handshake fails, try setting proto to tlsv1.
1234567891011121314151617181920212223
require('socket') require('ssl') host = '127.0.0.1' port = '443' proto = 'tlsv12' -- can also be 'tlsv1' or 'tlsv11' sock = socket.tcp() res, err = sock:connect(host, port) if res then   sock = ssl.wrap(sock, proto)   res, err = sock:dohandshake()   if res then     ...   else     log('Handshake failed', err)   end else   log('Connect failed', err) end sock:close()
(04.02.2016, 09:42)admin Wrote: For now we only have support for SSL/TLS in client mode, here's a short example. If handshake fails, try setting proto to tlsv1.
Thank you,
Is it possible to make it also for server mode (copas)?
Marek H.
Give us some time to finish the next FW release, then we'll update the SSL library with server part Smile
