I have a little question. How can I reset KNX device without ETS. E.g. is there a possibility to send via LM such commands like on this screenshot from ETS? (reset Busch Prion via ETS)
I would very much like to know too.
Does anyone have a solution to this?
Me too but I dont think its possible, only ping a physical address:-(
I’m suprised on how many users want this feature, i never have to restart a device and never hear any customer about it. So my questions are: Why do you need it and is this brand related?
If I know that there is some function which could be useful in the future for remote commissioning and it is not very hard to develop I try to develop it or submit it to someone who can.
Reset(or disconnecting the KNX cable) was useful for me very rarely only for Busch Prion with TFT which sometimes after restart after programming not load its program and it must be restarted to try again. But this is only when some device has complex program and if it has program after update which can have some bugs. Having some feature is better than not having it and has a client which stays in front of nice TFT button which is not fully loaded and you cannot do nothing
I also seen on trades other touch panels with android and I saw that they are also not so stable like simple pushbutton that I think that it's good to have possibility to restart it
This is very, very rarely and happily KNX and LM are very reliable devices
I am using Zennio KLIC-DA interfaces for Daikin Altherma heat pumps.
This interface is supposed to be able to read the energy consumption and production of the heat pump. I discovered that these readings only took place after using the control panel on the heat pump which is of course not the idea of Smart Home...
Zennio were unaware of this because they always tested their system in combination with the control panel...
I filed a ticket with Zennio and this issue was referred to their engineering department. However, after eight months they have not produced an update of their ETS application program...
I discovered that when I reset the device it would read the energy values, so this seemed a good intermediate solution. Further testing however revealed that resetting the interface caused the heat pump to switch off or revert to cooling instead of heating...
I also have had occasions with Basalte Auro movement sensors that would get 'stuck' and needing a reset...
readbusvoltage(addr) - returns bus voltage read from a given phys. address
isconnected() - returns true when KNX is connected, false otherwise
getstats() - returns Lua table with KNX/IP and KNX/TP telegram stats
I agree, this could be the beginning of the end...
It is for diagnostics.
And lets say you do some changes to the DALI lights and download the DALI GW, Then maybe some lights are on, some are off, but the PIR has already sent the ON-command and will not send a new one until the timer runs out and it then detects a new movement.
To correct this, one can reset the PIR, and if you have a script doing this, you only need to push a button to achieve it. Although, it has become more easy to do in ETS now than it was before...
I want to reset knx device because some one creat the bcu key in ets for give extra monay from customer
