if else
Im trying to get a pump to work, only if come conditions are met.
I am not good at scripting, but tried to make this script, but doesnt work properly.
Can anyone advice? Wink
value = grp.getvalue('1/5/1 or 1/5/2 or 1/5/3 or 1/5/4 or 1/5/5 or 1/5/6 or 1/5/7 or 1/5/8 or 1/5/9 or 1/5/10')
if (value == "on") then
  grp.write('1/4/23', true)
else grp.write('1/4/23', false)
Can't you use FBeditor for this? No scripting there.
Kai-Roger
Kai-Roger
(08.10.2018, 11:07)Bobby Wrote: Im trying to get a pump to work, only if come conditions are met.
Function grp.getvalue() returns true or false not "on" of "off".
Function grp.getvalue() takes only one group address so it should be:
value = grp.getvalue('1/5/1') or grp.getvalue('1/5/2') -- and others values grp.write('1/4/23', value)
Done is better than perfect
Assign a tag to your objects and use this script: https://forum.logicmachine.net/showthrea...18#pid1518
Another solution: https://forum.logicmachine.net/showthread.php?tid=1524
That looked easy enough Smile
Where do you put this to make it work? Is it under "Event-based" under scripting?
Which "Group adress / tag:" do we have to chose prior to insert this code?
First example is a resident script, second one is an event script.
In any case, all input objects for "or" gate must have the same tag. This tag must be either specified in resident script groups table or assigned to the event script.
