GA import from ETS
Any other way of importing GA from ETS, except the .esf ?
As GA which are not linked to any group objects in ETS, are not imported to the LM.
Any ideas which would help, because I need to create lot of GAs (around 250-300) in LM.
Place a Dummy Application in your ETS at that place your LM is located and fill it up with your GAs.
After that you can export the ESF with GAs you need.
Or you can convert ETS4/5 knxproj file to JSON at http://openrb.com/knxproj then use import JSON in utilities tab
Or you can create them from script:
for i = 0, 255, 1 do  address = grp.create({      datatype = dt.bool,      address = '1/1/' .. i,      name = 'Object ' .. i,      comment = 'Auto created by script',      units = '',      tags = {},  }) end
Great, Thank you all.
I've a similar question. Can I update names of already existing group objects from ETS to LM?
