29.10.2017, 06:43 (This post was last modified: 31.10.2017, 06:56 by Habib.
Edit Reason: typo
I made yesterday an update from my Fw 2.0.1 to 2.1.0.
Now I have the issue, that my Visu Switches are broken.
I define a switch with an main object 1 Bit and a status object 1 Bit. If I test it in my Visualisation Tab of the configuration it works fine as it should. But if I call the same Visu Page in my Browser (Firefox) I can only switch one time.
Example: I call the visu page and the light is off. I'm able to switch it on. The status is correctly shown. Now I press again, but it sends only ON to all actors. The status is ON already.
Now I refresh my page and the status is shown correctly (State ON) and I press again. It switch off.... the status is OFF and I want to switch them on again, but it's sends only OFF.... until I refresh again :-(
Have you change something in the behaviour of the Visualisation?
I've tested it with Firefox 56.0.2 (OSX), Firefox 56.0.2 (Win7) and Safari 11.0 (OSX 10.13)
Maybe it's a bug with FF 56.0.2? It's already released yesterday, or not?
EDIT: the solution at moment is to install (downgrade) the firmware 2.0.1
Yesterday I have to replace a HL by a HW W4K with FW 2.1, i had exactly the same issue!!
No more command since the display device worked.
The only thing that I found to help out my customer is an upgrade with lm5m3-20170620, and there all works very well !!
@Erwin: I think that it is necessary to plan an update quickly.
29.10.2017, 07:57 (This post was last modified: 29.10.2017, 08:05 by Habib.)
Hi Erwin,
thx for the fast help. I've installed the package but my issue is not fixed with it.... not fully fixed with it. In Firefox it works now correct, but if I open the page in my security app and wants to switch, it's the same behaviour than before....
The security app is able to open pages as an "virtual cam device" as widget....
29.10.2017, 08:02 (This post was last modified: 29.10.2017, 08:07 by Erwin van der Zwart.)
That's strange, i have updated all my test controllers (SL / HL / 4WK) and all are working. Did you unpack it and run it from Utilities -> Install updates ?
Try clearing browser cache or maybe a reboot? (not sure i did that)..
