Help decoding JSON data from socket.http.request
Dear All,
I'm trying to retrieve consumption info from an "Ecocompteur" box from Legrand with the following code, but it does not work as expected.
The returned Content-Type is "text/plain" while it should be "application/json", so the json.decode function does not work.
Is there another way to retrieve data values from the returned "json" data ?
Thanks in advance
Accessing "http://192.168.1.xx/inst.json" give this data in return :
   "data1":27.000000,
   "data2":0.000000,
   "data3":0.000000,
   "data4":0.000000,
   "data5":0.000000,
   "data6":0.000000,
   "data6m3":0.000000,
   "data7":0.000000,
   "data7m3":0.000000,
   "heure":22,
   "minute":5
require 'ltn12'
require 'socket.http'
json = require("json")
local request_url = "http://192.168.1.xx/inst.json"
local response_body = {}
local body, code, hdrs, stat = socket.http.request
    url = request_url;
    sink = ltn12.sink.table(response_body);
log (body, code, hdrs, stat)
-- local response_decode = json.decode(table.concat (response_body))
log (response_body)
-- local data1 = response_decode.data1
-- local data2 = response_decode.data2
Here is the log output :
Ecocompteur 01.11.2017 20:33:54
* arg: 1
 * number: 1
* arg: 2
 * number: 200
* arg: 3
 * table:
  [server]
   * string: lwip/3.0
  [content-type]
   * string: text/plain
* arg: 4
 * string: HTTP/1.0 200 OK
* string: {
   "data1":35.000000,
   "data2":0.000000,
   "data3":1.000000,
   "data4":0.000000,
   "data5":0.000000,
   "data6":0.000000,
   "data6m3":0.000000,
   "data7":0.000000,
   "data7m3":0.000000,
   "heure":20,
   "minute":33
}HTTP/1.0 200 OK
Server: lwip/3.0
Content-Type: text/plain
   "data1":35.000000,
   "data2":0.000000,
   "data3":1.000000,
   "data4":0.000000,
   "data5":0.000000,
   "data6":0.000000,
   "data6m3":0.000000,
   "data7":0.000000,
   "data7m3":0.000000,
   "heure":20,
   "minute":33
Try  this:
if type(response_body) == 'table' then
  data = json.pdecode(table.concat(response_body))
  data = json.pdecode(response_body)
log(data)
Try running this then post both log entries. What it looks like is that the response is incorrect. JSON functions expect valid input which does not have "Content-Type" set anywhere so it's not the problem.
require('json')
require('socket.http')
url = 'http://192.168.1.xx/inst.json'
data = socket.http.request(url)
log(data)
log(json.pdecode(data))
(02.11.2017, 06:55)admin Wrote: Try running this then post both log entries. What it looks like is that the response is incorrect. JSON functions expect valid input which does not have "Content-Type" set anywhere so it's not the problem.
require('json')
log(data)
Here is the log entries I got :
Ecocompteur 02.11.2017 07:58:47
* string: {
   "data1":195.000000,
   "data2":0.000000,
   "data3":0.000000,
   "data4":173.000000,
   "data5":0.000000,
   "data6":0.000000,
   "data6m3":0.000000,
   "data7":0.000000,
   "data7m3":0.000000,
   "heure":7,
   "minute":58
}HTTP/1.0 200 OK
Server: lwip/3.0
   "data1":195.000000,
   "data2":0.000000,
   "data3":0.000000,
   "data4":173.000000,
   "data5":0.000000,
   "data6":0.000000,
   "data6m3":0.000000,
   "data7":0.000000,
   "data7m3":0.000000,
   "heure":7,
   "minute":58
* arg: 1
 * nil
* arg: 2
 * string: Expected the end but found invalid token at character 253
(I PM you more info)
Thx
(01.11.2017, 21:50)Erwin van der Zwart Wrote: Hi,
Try  this:
log(data)
Thx Erwin, but it does not work.
Here is the log entry :
Ecocompteur 02.11.2017 08:33:27
* nil
Strange, I've tested it with your access details and it works correctly. Which firmware version are you running?
Can you also try running request like this?
sock = require('socket').tcp()
sock:settimeout(5)
res, err = sock:connect('192.168.1.xx', 80)
if res then
  sock:send('GET /inst.json HTTP/1.1\r\n\r\n')
  res = sock:receive('*a')
  log(res)
  if res then
    p, e = res:find('\r\n\r\n', 1, true)
    if e then
      data = res:sub(e + 1)
      data = require('json').pdecode(data)
      log(data)
(02.11.2017, 07:44)admin Wrote: Strange, I've tested it with your access details and it works correctly. Which firmware version are you running?
1Version 2: 20170620
It should be the last I think ?
I'll try again ..
(02.11.2017, 07:48)admin Wrote: Can you also try running request like this?
sock:settimeout(5)
if res then
 log(res)
 if res then
   if e then
     log(data)
Thanks, it works perfectly !
