LM as webserver - ERR_INVALID_HTTP_RESPONSE
I have an "old" piece of code that generates a html response for clients that connects to my lm:
http://192.168.x.x:19001/getdata/test
Results:
Chrome : ERR_INVALID_HTTP_RESPONSE
IOS Safari : cancelling load from .... because it is using HTTP/0.9
Internet explorer and Edge works great.
Anyone a solution?
-- init server handler
if not ready then
 require('copas')
 -- list of client sockets
 clients = {}
 -- incoming data handler
 function datahandler(sock, data)
   local ip, port
   ip, port = sock:getpeername()
   -- send reply
   if string.find(data,"GET /getdata/test") then
     sock:send(htmlbody)
   --else
       --log(string.format('[server] data from %s:%d - %s', ip, port, data))
 -- connection handler
 function connhandler(sock)
   -- enable keep-alive to check for disconnect events
   --sock:setoption('keepalive', false)
   local ip, port, data, err, id
   -- get ip and port from socket
   -- client id
   id = string.format('%s:%d', ip, port)
   --log(string.format('[server] connection from %s', id))
   -- save socket reference
   clients[ id ] = sock
   -- main reader loop
   while true do
     -- wait for single line of data (until \n, \r is ignored)
     data, err = copas.receive(sock, '*l')
     -- error while receiving
     if err then
       --log(string.format('[server] closed connection from %s:%d', ip, port))
       -- remove socket reference
       clients[ id ] = nil
       return
     -- handle data frame
     if data == "" then
       --log("stop")
       break
 -- bind to port 10001
 tcpserver = socket.bind('*', 19001)
 -- error while binding, try again later
 if not tcpserver then
   os.sleep(5)
   log('[server] error: cannot bind')
 -- set server connection handler
 copas.addserver(tcpserver, connhandler)
 -- create udp server on port 10002
 udpserver = socket.udp()
 udpserver:setsockname('*', 19002)
 udpserver:settimeout(0.1)
 ready = true
-- perform server tasks for one second (5 x (0.1 + 0.1))
for i = 1, 5 do
 message = udpserver:receive()
 -- got message from udp, send to all active clients
 if message then
   --log("message: " .. message .. " : " .. chartobyte(message))
   for id, sock in pairs(clients) do
     --log("client id: " .. id)
     sock:send(message .. '\r')
 copas.step(0.1)
-- all dynamic pages
htmlbody =
"<HTML>\n"..
"\n"..
"<HEAD>\n"..
"<title>Web Communication</title>\n"..
"</HEAD>\n"..
"\n"..
"<BODY>\n"..
"Web Communication \n"..
"<h3>Test</h3>\n"..
"<pre style='white-space:normal;'>"..
"</pre>"..
"<br>"..
"</BODY>\n"..
"\n"..
"</HTML>"
Have you considered using .lp scripts with the main web server, or is the URL fixed on clients?
(20.11.2017, 10:47)admin Wrote: Have you considered using .lp scripts with the main web server, or is the URL fixed on clients?
Its a fixed url
Can i change something to have working code?
This should work. Another thing is that you probably don't need local UDP server here. If you want to send some dynamic data you can use storage.
if not ready then
  require('copas')
  htmlbody =
  "<html>\n"..
  "\n"..
  "<head>\n"..
  "</head>\n"..
  "\n"..
  "<body>\n"..
  "<h3>Test</h3>\n"..
  "</pre>"..
  "<br>"..
  "</body>\n"..
  "\n"..
  "</html>"
  function httpsend(sock, body)
    local resp = 'HTTP/1.1 200 OK\r\nContent-Length: %d\r\nContent-type: text/html\r\nConnection: close\r\n\r\n%s'
    local data = string.format(resp, #body, body)
    return sock:send(data)
  clients = {}
    local ip, port
    -- send reply
      httpsend(sock, htmlbody)
    --else
    -- client id
    -- main reader loop
    while true do
      if err then
        clients[ id ] = nil
        return
      if data == "" then
        --log("stop")
        break
    os.sleep(5)
  ready = true
for i = 1, 5 do
  if message then
  copas.step(0.1)
thanks
