Write one bit in register modbus
Hello, I am working with MODBUS  module for TESYS U and LM5, but I need to write one bit individually. For example set 602.1 to 1. Could anyone help me please? Thanks
Are you using profiles or scripts? In any case you will need a script to assemble final register value because profiles do not support writing individual bits.
(20.12.2017, 13:38)admin Wrote: Are you using profiles or scripts? In any case you will need a script to assemble final register value because profiles do not support writing individual bits.
I am using scripts, have you any sample of this kind of scripts? Thanks
As far as I understand, only one bit from 0..2 range can be set to 1. For this control I suggest creating 1-byte unsigned integer
object and assign custom values (0 = set bit 0, 1 = set bit 1, 2 = set bit 2) to it so you don't have to create binary objects for each bit.
mode = grp.getvalue('1/1/1') -- 1-byte unsigned integer paridad = grp.getvalue('1/1/2') -- boolean control = grp.getvalue('1/1/2') -- boolean if mode == 2 then   value = 4 elseif mode == 1 then   value = 2 else   value = 1 end if paridad then   value = value + 8 end if control then   value = value + 16 end log(value)
