Single/double press detection from www.logicmachine
Hello everyone, I used the script from www LogicMachine/Documentation and examples - Single/double press detection. I followed the instructions and the script did not work. After restarting LogicMachine it worked, but after editing it stopped working and restarting LogicMachine didn't help either. Has anyone encountered something similar or any ideas? Thanks Borek
Check that the resident script sleep time is set to 0.
(11.04.2024, 10:44)admin Wrote: Check that the resident script sleep time is set to 0.
Yes, I have...
Post your script. What exactly have you changed?
(11.04.2024, 14:45)admin Wrote: Post your script. What exactly have you changed?
-- maximum time between presses
presstimeout = 0.5
mapping = {
  ['9/0/0'] = {
    -- single press
    single_address = '9/1/0',
    single_value = FALSE,
    -- double press
    double_address = '9/2/0',
    double_value = TRUE,
    -- multi (3+) press (optional)
    multi_address = '9/0/9',
    multi_value = 33,
  ['9/0/1'] = {
    -- single press
    single_address = '1/3/40',
    single_value = TRUE,
    -- double press
    double_address = '1/3/41',
require('copas')
function write(map, key)
  local address = map[ key .. '_address']
  local value = map[ key .. '_value']
  if address and value ~= nil then
    grp.write(address, value)
    return true
function timerthread(addr, map)
  local counter = 0
  local timeout = -1 -- suspend thread
  while true do
    copas.sleep(timeout)
    if map.counter == counter then
      if timeout == presstimeout then
        if counter == 1 then
          write(map, 'single')
        elseif counter == 2 or not write(map, 'multi') then
          write(map, 'double')
        timeout = -1
        counter = 0
        map.counter = 0
      timeout = presstimeout
      counter = map.counter
for addr, map in pairs(mapping) do
  map.counter = 0
  map.thread = copas.addthread(timerthread, addr, map)
function eventhandler(event)
  local map = mapping[ event.dst ]
  if map then
    map.counter = map.counter + 1
    copas.wakeup(map.thread)
lb = require('localbus').new(1)
lbConfusedethandler('groupwrite', eventhandler)
copas.addserver(lb.sock, function()
  lb.sock = copas.wrap(lb.sock)
  while true do
    lbConfusedtep()
end, 1)
copas.loop()
ONLY: adress and value...
true/false must be in lowercase
(11.04.2024, 15:10)admin Wrote: true/false must be in lowercase
Thank you very much, I forget that LUA has to be lowercase.....Sad((
