Threads: 41
In the manual there is a warning that excessive object logging degrades performance.
Is the same true for object exporting?
Threads: 30
No, when you export you ether create BACnet object or webservice but nothing is saved. When you log objects then x amount of data is saved each time tellegram is received.
For sure whey you export lots of objects cpu will go up but this this is related to everything.
Threads: 103
How often are logged values written? Is it immediately or in 30 minutes cycles like trends etc?
Thank you
Threads: 30
(06.02.2018, 14:22)Thomas Wrote: Hi
Thank you
in 30 min. This would kill card immediately...
