06.02.2018, 21:26
Hi Everyone:
I have a project with 10 knx lines, and inside each line I have connected an IPS/S 3.1.1 from abb, and all connected to and network switch. My question is: Can I get information from each knx lines using KNXnetIP tunneling with one logicmachine?? I dont want to connect the logicMachine in one of the KNX lines, in deed, I don want to use the TP knx connector in logicmachine, all connection must be IP.
The gol is use the logic machine to get humity information from diferents buildings, calculate certains parameters using specific formules and send back information each building using only KNXNetip tunneling protocol. I don want and I can not use routing because each building is in a separated network all aroud the world...
Is there any option to get information from diferents KNX Lines only using KNXnetIp tunneling protocol???.
best regards
best regards
