Threads: 39
Hi, I try to restore backup from Spacelynk v2.0 to another spacelynk v2.1 and several backup failed to restore (invalid).
Do you know if there is a trick/fle to modify in backup to reimport easily all my backup to different customer project.
I have one spacelynk and one homelynk as demo server for customer that i use to present and develop before deploying it to customer building.
SE ECO EXPERT
Threads: 39
I try with several different backup file and still the same error (Backup file is invalid)
I also try to reset the Spacelynk without sucess
I can open the archive file.
SE ECO EXPERT
Have you made any changes to the backup file using 7Zip or other utility?
Threads: 39
(09.02.2018, 11:17)admin Wrote: Have you made any changes to the backup file using 7Zip or other utility?
none ! I tried to restore at least 5 different project without any sucess !
Lots of them was made on Spacelynk and homelynk 2.0.1 firmware.
I can't restore it on my Spacelynk 2.1.1 firmware ! Any of them are accepted !
The fun point is that partial program are imported (but still message invalid file), but looks like some picture are missing.
SE ECO EXPERT
Threads: 8
09.02.2018, 11:44
(This post was last modified: 09.02.2018, 11:45 by Erwin van der Zwart.)
Can you open the back-up with a compressed folder application like 7Zip? What is the size of your backup? Is it a couple of Kb's? Could be corrupt backup-up sets..
Threads: 39
09.02.2018, 11:48
(This post was last modified: 09.02.2018, 11:51 by domotiqa.)
(09.02.2018, 11:44)Erwin van der Zwart Wrote: Hi,
Thank for your help.
No backup are ok ! I can open it, I used them several time before (like template for me). And I try different project to test.
The backup are at least 4MO
I sent you the link and the backup example.
It's a test server, feel free to do any action on it without risk.
SE ECO EXPERT
Threads: 31
Did you try this backup on different device ?
Threads: 8
09.02.2018, 11:56
(This post was last modified: 09.02.2018, 11:56 by Erwin van der Zwart.)
I just imported your backup into my W4K without issues, so your back-up is valid.. and your project/work is save (:
Now we need to check why you can't upload it in yours..
Threads: 39
09.02.2018, 12:12
(This post was last modified: 09.02.2018, 12:14 by domotiqa.)
(09.02.2018, 11:56)Erwin van der Zwart Wrote: Hi,
just think about disabling the script in resident about the dns update or the customer would not have access to his server again but to yours ;-)
(09.02.2018, 11:53)Daniel. Wrote: Hi
yes David, the backup is Ok !
In the past I used to import backup from Spacelynk to Homelynk, from Homelynk to Sapcelynk, from different version of firmware... without issue. I hope that it will continue like this because I have several backup I used as template for different customer project before deploying it in their building !
SE ECO EXPERT
Threads: 8
09.02.2018, 12:25
(This post was last modified: 09.02.2018, 12:25 by Erwin van der Zwart.)
I just uploaded the backup into your device without issues..
Can you clear browser chache, try with disabled virus scanner or use another browser / pc to test yourself?
Threads: 39
09.02.2018, 13:39
(This post was last modified: 09.02.2018, 16:02 by domotiqa.)
(09.02.2018, 12:25)Erwin van der Zwart Wrote: Hi,
ok looks like it's a cache problem after upgrading the firmware from 2.1.0 to 2.1.1 and not refresh my browser cache
Thanks for help !
SE ECO EXPERT
Threads: 3
I update my Wiser for KNX, HomeLynk to version 2.x.x to the new version 3.0.0
The firmware update was successfully. now it shows:
HW: Wiser for KNX (i.MX6)
SW: 3.0.0
But I lost all group addresses, trends, scripts, modbus configuration, visualizations.
I try to import the backup file generated just before the firmware update but that has no effect.
My icons and images/background are present.
LOG:
May 6 05:37:51 Wiser for KNX user.info sysinit: md5sum: WARNING: 1 of 1 computed checksums did NOT match
May 6 05:37:51 Wiser for KNX user.info sysinit: /lib/genohm-scada/storage/backup.db: FAILED
May 6 05:37:51 Wiser for KNX user.info sysinit: md5sum: can't open '/lib/genohm-scada/storage/backup.db': No such file or directory
May 6 05:37:51 Wiser for KNX user.info sysinit: /lib/genohm-scada/storage/current.db: FAILED
May 6 05:37:51 Wiser for KNX user.info sysinit: md5sum: can't open '/lib/genohm-scada/storage/current.db': No such file or directory
May 6 05:37:51 Wiser for KNX user.info sysinit: sed: can't create temp file '/lib/genohm-scada/storage/db/backup.md5XXXXXX': No space left on device
May 6 05:37:51 Wiser for KNX user.info sysinit: sed: can't create temp file '/lib/genohm-scada/storage/db/current.md5XXXXXX': No space left on device
May 6 05:37:51 Wiser for KNX user.info sysinit: mv: can't preserve permissions of '/lib/genohm-scada/storage/db/trends': No space left on device
May 6 05:37:51 Wiser for KNX user.info sysinit: mv: can't preserve ownership of '/lib/genohm-scada/storage/db/trends': No space left on device
May 6 05:37:51 Wiser for KNX user.info sysinit: mv: can't preserve times of '/lib/genohm-scada/storage/db/trends': No
If I unzip the backup file. I can open the database current,md5 and browse the rows inside the tables.
What should I have to do ?
Perform a factory reset and try restoring the backup again. If it does not help then re-flash the SD card: https://kb.logicmachine.net/misc/reflash...ng-player/
Threads: 3
I re-flash the SD-Card.
I can only import my project backup only if the firmware is V2.1.0.
If update from V2.10 to higher (V2.3.0, V2.6.2, V2.8.0, V3.0.0) I lost all data. If after re-flash the SD-Card I use an higher firmware , and I import my project nothing happened, still empty.
I can use again my product, and that is the more important, but how can update it to more recent firmware?
Threads: 31
Send me your backup to PM. Which hw version do you have?
Threads: 31
You have too many trends there, In old firmware they were stored differently. Use 7zip, edit your backup and delete some trends. Save while closing 7zip.
