Combo box on visualization
I would like to put a combo box on in visualization from wich I can choose a value (taken from an array, string in that case) to update a address group.
Do you have any solution?
Thank you
Peppe
Add Custom values to control object and set Control type to "Custom value select" in Vis. parameters
(17.04.2018, 10:04)admin Wrote: Add Custom values to control object and set Control type to "Custom value select" in Vis. parameters
Sorry, I don't understand
Can you give me an example?
Thank you so much!
I just need the last puzzle card: how I can do the above via script? I need to:
1) read an array of string
2) create or update the display text value for every object value with each string of the array
Peppe
Can you explain what kind of task do you have? Another solution is to create html select element via Custom JavaScript.
(17.04.2018, 13:04)admin Wrote: Can you explain what kind of task do you have? Another solution is to create html select element via Custom JavaScript.
That's my script:
ok I can get the playlist name to play with your hints, but... I get the playlists every time with:
playlists = http://192.168.0.107/api/v1/listplaylists
which an array. So i have to update time by time the value on '32/1/19' with the elements of the array.
value = event.getvalue()
address = event.dst
if value then
 playlist = grp.getvalue('32/1/19')
require('socket.http')
socket.http.TIMEOUT = 5
 socket.http.request('http://192.168.0.107/api/v1/commands/?cmd=playplaylist&name='..playlist)
 os.sleep(2)
 grp.update(address, 0)
You can overwrite custom values with grp.create. You will need a scheduled script to reload playlist from time to time. You will also need to put this list into storage so you can get playlist name from numeric object value in your event script.
grp.create({
  address = '32/1/1',
  enums = {
    [0] = 'Playlist 1',
    [1] = 'Playlist 2',
    [2] = 'Playlist 3'
This will still require visualization reload in case custom values are changed.
Great!
Thank you so much.
Peppe
(18.04.2018, 08:35)admin Wrote: You can overwrite custom values with grp.create. You will need a scheduled script to reload playlist from time to time. You will also need to put this list into storage so you can get playlist name from numeric object value in your event script.
grp.create({
 address = '32/1/1',
 enums = {
   [0] = 'Playlist 1',
   [1] = 'Playlist 2',
   [2] = 'Playlist 3'
Please, can you give me the right code to require visualization reload by button clicking?
Here is a JS code sample to reload visu by KNX command:
$(function(){
  grp.listen('10/1/1', function(object, state) {
    var value = object.value;
    if (state == 'value') {
      if (value == true) {
        location.reload();
(20.04.2018, 12:30)Erwin van der Zwart Wrote: Hi,
$(function(){
        location.reload();
Thank you! Wink
