Movement sensor with lux condition
Hi!
I have a movement sensor who controls the lightning.
but i want a condition that says if the lightning level is above 300 lux, the lightning will not turn on.
does anybody have a good script for this?
This will work fine. Paste this inside the sensor switch object, change those group addresses which are marked 'x/x/x'.
value = event.getvalue() -- Value of current object LUX = grp.getvalue('x/x/x') -- change this to group address of your LUX sensor if (value == false) then -- turns off the light      grp.write('x/x/x', false) -- Change this to your light object group address end if (value == true  and LUX < 300) then -- condition to turn the light on when level of LUX is under 300.      grp.write('x/x/x', true) -- Also change this to your light group address object end
Also, if you are by any chance using Auro by Basalte, you don't need script at all, everything can be set-up in your ETS project.
