Threads: 32
hello
does anyone knows how can flasing an object?
i used the following but did not work
if event.getvalue() == true then
grp.write('1/2/16', flasing,2)
thanks in advance
Threads: 161
Do you mean flashing or blinking?
enableGA = '1/1/1'
outputGA = '1/1/2'
while grp.getvalue(enableGA) do
grp.write(outputGA, not grp.getvalue(outputGA))
os.sleep(1)
But what you try to exactly achieve?
Done is better than perfect
Threads: 161
20.06.2018, 21:36
(This post was last modified: 20.06.2018, 21:36 by buuuudzik.)
a) You can use FBEditor app and Control -> Oscillator.
b) If you want create script then you can create Resident script with 2 seconds interval and inside it type (fill with your GAs):
enableGA = '1/1/1'
outputGA = '1/1/2'
if grp.getvalue(enableGA) then grp.write(outputGA, not grp.getvalue(outputGA)) end
If you are using event-based script for blinking you must be careful to not create infinite-loop.
Threads: 35
Or find yourself nice GIF icon which flash and this will save you a lot of telegrams.
