Filtering info from loop
I'm trying to do scheduled scan of a tag weekly to ultimately send me an email with a report if something is wrong. However, I'm seeing that some info is left out. Logically I can see why, but I'm having some trouble fixing the logic for myself to see the solution...
First edition of script:
ecgFail = grp.tag('ecgFailure')
total = 0
for index, value in ipairs(ecgFail) do
 if value.data == true then
   total = total + 1
   name = value.name
log('Found '..total..' ECG(s) with failure. Id´s: '..name)
Output in the log:
* string: Found 2 ECG(s) with failure. Id´s: L5 - DALI ECG 3, Failure Status
As you can see I'm missing the name of the second ECG with failure. Any suggestions?
The log for individual errors should be in the loop.
(25.07.2018, 14:08)Daniel. Wrote: The log for individual errors should be in the loop.
Yeah, I figured that might be the solution. However, the end goal is to get them all neatly listed in an email. Wouldn't that just do the count wrong then? I understand I don't need the count, but its fun to learn something new in the process Wink
Try something like that
total = 0
buffer = { 'Name' }
   total = total + 1
   name = value.name
buffer[ #buffer + 1 ] = table.concat({
 name,
csv = string.char(0xEF, 0xBB, 0xBF) .. table.concat(buffer, '\r\n')
res, err = mailattach('someone@example.com', 'Report', 'CSV file attached', 'report.csv', csv, 'text/csv')
Use email function from here
https://forum.logicmachine.net/showthrea...94#pid1994
