Modbus and RS485 communications
in the past I used LM only as the gateway to KNX + visualization.
I used basic scripts in LUA.
Now I get to the project, where MODBUS communication and RS485 communication is needed. I went through the forum and still do not know how to do it.
Are there any examples of crypts for RS485 communication and Modbus communication or manual?
The Modbus-TCP communication will be used to control the massage bathtub.
RS485 communication will be used to control the fireplace.
I have communication protocols for the device.
I have LM5 IO V2 available.
Thank you for your help.
The easiest way to interface modbus devices is to use profiles/built-in mapper: http://openrb.com/docs/modbus.htm
Serial communication library is also built-in: http://openrb.com/docs/serial.htm
There's also an example of Denver e-Ribbon Fire control: http://openrb.com/logicmachine-as-gatewa...ibbon-fire
