20.10.2018, 21:13
I am sharing a way to send easily object values to influxdb.
Update server and database name before using it.
influx_clim send object with tag "influx_clim"
add "influx_clim()" to a schedule for automatic export
123456789101112131415161718192021222324252627282930313233343536373839404142434445464748495051525354555657585960616263646566676869707172737475767778798081828384858687888990919293949596979899100101102103104105106107108109110111112113
require 'ltn12'
require 'socket.http'
local https = require("ssl.https")
local influxdb_debug = true
local influxdb_server = "https://user:pass@host:8086"
local influxdb_database = "db_name"
local influxdb_buffer
--function used to convert object name (logicmachine) to valid influxdb field key
function influxdb_normalize(name)
return string.gsub(name, " ", "_")
--add an entry to be send
function influxdb_add(line_protocol)
if (influxdb_debug) then
alert("influxdb_add start")
if influxdb_buffer then
influxdb_buffer = influxdb_buffer .. "\n" .. tostring(line_protocol)
influxdb_buffer = tostring(line_protocol)
alert("influxdb_add done")
function influxdb_current()
return influxdb_buffer
-- send the buffer to influxdb
function influxdb_send()
alert("influxdb_send start")
local request_insert_url = influxdb_server .. "/write?db=" .. influxdb_database
-- log(influxdb_buffer)
local response_body = { }
local body, code, hdrs, stat = https.request
url = request_insert_url;
verify = "none";
method = "POST";
headers =
["Content-Length"] = #influxdb_buffer;
source = ltn12.source.string(influxdb_buffer);
sink = ltn12.sink.table(response_body);
influxdb_buffer = nil
if (code ~= 204) then
alert("influxdb error code:" .. tostring(code))
alert("influxdb_send http post error")
alert("influxdb_send done")
--export all objects with tag "influx_clim"
function influx_clim()
local values=grp.tag("influx_clim")
alert("influx_cilm start")
local txtvalues = ""
for index, id in ipairs(values) do
-- add separator
if (#txtvalues>0) then
txtvalues = txtvalues .. ","
-- calculate value to be sent
if (type(id["data"])=="boolean") then
value=id["data"] and 1 or 0
value=id["data"]
-- add key value pair
txtvalues = txtvalues .. influxdb_normalize(id["name"]) .. "=" .. value
influxdb_add("clim " .. txtvalues)
influxdb_send()
if (debug) then
alert("influx_cilm end")
