-- Continously invoke mqtt_client:handler() to process the MQTT protocol and
-- handle any received messages. Also, publish a message on topic "test/1"
running = true
while (running) do
mqtt_client:publish("test/1", "test message")
socket.sleep(1.0) -- seconds
-- Clean-up by unsubscribing from the topic and closing the MQTT connection
Upgrade firmware to 2018 RC1. It has built-in MQTT library support and some other features required for this script.
Create resident script with 0 sleep interval. Change broker IP address and mapping tables as needed. mqtt_to_object maps topic to a group address, object_to_mqtt maps group address to atopic.
Do full script restart via disable/enable when changing any mapping tables and/or broker address.
if not broker then
broker = '192.168.1.101'
function multiply(mult)
return function(value)
local num = tonumber(value)
if num then
return num * mult
return value
03.12.2018, 10:18 (This post was last modified: 03.12.2018, 10:57 by pentadom.)
(03.12.2018, 08:43)admin Wrote: Upgrade firmware to 2018 RC1. It has built-in MQTT library support and some other features required for this script.
I'm trying to do this but it doesn't works. I supose that when I send a value to the broker, automatically the script must receive the value?
I've just upgrade the firmware. Here's the actual version:
Here's my code where I put the mosquitto test broker and the topic "arqueta/humedad" I'm testing. the object 32/1/1 is a "05. 1 byte unsigned integer".
As I say, it doesn't works and I don't know what I'm doing wroing.
The correct line to broker is without "http://"
I have problem with object_to_mqtt this topic will change on MQTT when I write new value? Is it necessary event script? Now I don't see change this value on client.
No event script is needed. Value is published to selected topic when value changes. Have you checked that MQTT client is connected? Does the reverse (mqtt_to_object) work? Does the client have access to the select topic?
You can log the publish result like this (line 83):
local r, e, c = mclient:publish(topic, tostring(value))
log('publish', r, e, c)
if res then
mclient:subscribe('100')
mclient:disconnect()
mclient.ON_MESSAGE = function(mid, topic, payload)
if topic == '100' then
if payload == "C,1,1,\r\n" then
grp.write('0/0/1', true)
elseif payload == "C,1,0,\r\n" then
grp.write('0/0/1', false)
elseif payload == "C,2,1,\r\n" then
grp.write('0/0/2', true)
elseif payload == "C,2,0,\r\n" then
grp.write('0/0/2', false)
Using one topic for controlling multiple entities is bad system design. Each relay should have it's own topic for control if possible.
please elaborate this custom Logic in Mqtt callbacks where we can i find
actually am adding this logic in main residence script please find it in attached file(how we have done)
am doing it in correct way...?
Check the latest log entry, it shows what data was published to the topic named "100". Modify the ON_MESSAGE callback function to execute actions based on the received payload:
log('ON_MESSAGE ', topic, payload)
if payload == "11" then
elseif payload == "10" then
You can use MQTT explorer (http://mqtt-explorer.com/) to connect to LM and send any data to any topics to test your scripts.
in this case the publishing topic=100, and Payload=C,1,1,1,\r\n like this format while subscribing topic=100 and msg Payload=$FD;2;4;0;0;0;0;0;0;@ while watching from LM log we found this.
