Alexa App Temperature
Hi everybody,
I am testing Alexa in Italian. Everything works fine but I have some problem with temperature skill.
I mean that I can set temperture set point to a group address by voice but in device profile of Alexa app "A problem occurs is shown". How can be?
Furthermore I have a KNX temperature sensor and I would like required to Alexa the status of temperature. It seems does not work. Furthermore I found command address, status address and scale. In the scale I find a group address. Is it correct?
To be able to ask for temperature use skill 'Temperature' then you can ask 'Alexa, what is ''thermostat name'' temperature?'
No idea how to say it in Italian Wink
(10.12.2018, 11:09)Daniel. Wrote: Hi
Hi Daniel,
I found the problem. In the label I used the word temperature hence Alexa does not clearify the question.
Hence I simply set the name of the thermostat and everything was fine.
I have the same problem on French Alexa.
In the scale I find a group address at the place Celsius or Kelvin.
In alexa app, there is a message "a problem has occurred"
Other skill works well !
Where is the problem? Huh
jean-Marc
Jean-Marc
We are aware of this issue, suddenly this stopped to work. It looks like Amazon has changed something in the API without any notice. We are looking on it but if new certification will be needed then it will take a while.
Thanks Daniel
They are abusing a dominant market position Blush
Jean-Marc
Daniel ,
wouldn’t the problem be related to the temperature sensor on Echo Plus second generation?
https://www.amazon.com/gp/help/customer/...CTQMN6DQ2X
Jean-Marc.
Jean-Marc
In fact it is quite the skills which manage the thermostats which do not work any more !!
Jean-Marc.
Some errors on Alexa script
Jean-Marc
This is usually related internet connection problems. My is working fine.
(22.01.2019, 09:55)Daniel. Wrote: Hi
Hi Daniel
Have you news of this problem?
Jean-Marc
Hi Daniel
still no news
Jean-Marc
Jean-Marc
Hi Daniel
still no news
Jean-Marc
New skill is under certification.
Great news Daniel !
You will notify when the new skill will be ok  Big Grin
Jean-Marc
Jean-Marc
Hi Daniel
still no news
Jean-Marc
Hi Daniel,
still no news ?
Jean-Marc
Still no certification for the new skill ?
jean-marc
Jean-Marc
(17.05.2019, 05:18)JMM Wrote: Hi,
jean-marc
it didn't work, we are exchanging with the support as the issue seems to be on amazon side. Painful process but we didn't gave up.
jean-marc
It's an unequal contest ! Dodgy
Jean-Marc
