Threads: 30
Is it possible to create/delete a scheduler with defined parameters (name, controlled object, events with their starting times/values...) with a script? if so, how?
Thanks in advance.
Threads: 30
Thanks for Your answer. Yes, I'm already aware of the possibility of modifiying schedulers with DB queries. In future would be very nice to see ability to create/delete schedulers from a script.
Threads: 8
FW 2.4.0 is just released and should be already or comming soon on our website.
in this version we added enabling schedulers by object.
Threads: 103
I do the same thing. I've primary and backup LM.
My code for enabling/disabling schedulers is here:
function _clearschedulers()
local files = io.ls('/tmp')
for _, file in ipairs(files) do
if file:find('lm-scheduler-', 1, true) then
os.remove('/tmp/' .. file)
function ecl_enable_all_schedulers(ai)
-- ai must be 0 - inactivate 1 - activate
db:update('schedulers', {
active = ai
_clearschedulers()
Threads: 10
02.08.2019, 14:52
(This post was last modified: 02.08.2019, 14:53 by equalizer.)
In the Schedule Events db entry what is the function of "offset_hour" "offset_min", do these advance and delay the timer? If so does it handle day rollover (if say off time is advanced beyond midnight)?
This only affects sunrise and sunset modes. Rollover cases are handled.
