Problems with FB Editor
Good morning,
I'm trying to start with the function block editor but i have some problems because i never used something like this before. And the manuals dont reallly help me.
I understand the general structure of the editor but fail yet with a simple logic like this:
I have an "or function block" with two inputs. Both inputs are true/false objects (e.g. 32/1/1 and 32/1/2) and the function is triggered by one of them. The output is the object 32/1/3.
 If i test the function the value of the output 32/1/3 only can change between true and false.
How can i reach now if one of the inputs is true the output writes an other value (e.g. ASCII text) on 32/1/3 and if both inputs are false again an other value?
Thank you for your help!
Check this video
https://www.youtube.com/watch?v=MHQ7s5imZdk
Thank you for the quick response, i saw this video yet but it didn't help me.
In the video the output is true or false. But i want that the output is a specific value in an other datatype.
I am sorry for this perhaps its too high for me.
If you need this for visualization you can use custom values option to map specific text to true/false values.
You can do it like that, but if you need this just for visu then do it like admin said.
.json   text select.json (Size: 11.13 KB / Downloads: 24)
(11.04.2019, 12:53)Daniel. Wrote: You can do it like that, but if you need this just for visu then do it like admin said.
This is function i looked for.
Thank you very much
