Threads: 9
In LM's Users tab, you can add users with respective usernames and passwords. The same you need to put in Linphone app. Remember that the usernames should be numerical.
Threads: 103
I see there's a SIP server there. Can this server trigger an GO based action? And vice versa can GO trigger SIP server action?
Could we have SIP client too? I mean a piece of code which can answer SIP call, authorize the user (by pnone number, PIN) and do a simple action like opening door etc triggered by dialed tones?
It would be great and I think cheap improvement.
Threads: 7
My experience with SIP clients in browsers (WebRTC) is that they require WSS and that means SSL certificates and everyting, it's not a cheap add on and certainly not simple..
Threads: 103
(19.07.2019, 12:02)Erwin van der Zwart Wrote: My experience with SIP clients in browsers (WebRTC) is that they require WSS and that means SSL certificates and everyting, it's not a cheap add on and certainly not simple..
I meant SIP client running on LM. Not web based SIP client.
Threads: 7
And the LM is not web based?
