SQL COUNT
I am having some trouble getting a number from the SQL COUNT.
I am using this conde:
ant = db:getrow('SELECT COUNT() FROM objects WHERE name LIKE "%status%"')
log(ant)
The result I get from this in the log is then;
* table:
[COUNT()]
  * number: 569
What I need is to just get the number stored in the variable, not the entire table. Any good tips for me?
There are 10 kinds of people in the world; those who can read binary and those who don't  Cool
Use getone() instead of getrow()
(06.09.2019, 08:32)admin Wrote: Use getone() instead of getrow()
As a charm!
Perfect.
I am now having a similar challenge, but this time with the table I get from the string.split function. I have the following code;
startHG = string.split(start, '/')
This takes the Group address and splits it to the three values from the addres, giving med the table;
* table:
[1]
  * string: 26
[2]
  * string: 0
[3]
  * string: 0
How can I now get the different values entered in seperate variables? I would like to have a variable for maing group (e.g. mg) that should have the value 26 and so on.
* table:
[1]
  * string: 26
[2]
  * string: 0
[3]
  * string: 0
Nevermind. I found it out by trial and error. The code needs to be;
startHG = tonumber(string.split(start, '/')[1])
That will get the main group as a number.
