Custom values (enums)
Hello
How to get safely custom values into a Lua table?
In Object.enums I see:
{"0":"OK","1":"On"..."255":"Error"}
I need a table containing:
t[0]="OK"
t[1]="On"
t[255]="Error"
Do you have a tested script which parse object.enums string into such table?
Thank you
enums are encoded using JSON so you need to use json.decode
Tank you.
The whole solution is:
myobject = grp.find("24/3/16") if (myobject.enums) then   json = require('json')   data = json.decode(myobject.enums)   log(data[tostring(myobject.value)]) end
